Question about Hardware & Accessories
How do I programme the tap timer?
Dificult to programme
  • 5,089 Answers
Copy following link.
http://www.popeproducts.com.au/products/garden-watering-products/tap-timers-amp-auto-control-systems/tap-timers
Tap timers show on page.
Click timer image that looks like your timer
Another page opens, than just below the timer image is link to pdf instruction manual.
Posted on Oct 30, 2012
My new Miele Washing Machine (Model no WDA 110) is not taking in water. The programme timer counts down but no water comes in thru powder/conditioner. We have checked the installation carefully and
Hi, Jane.
Is the tap on? (Sorry, I had to ask)
Make sure the filters on the inlet valve(s) aren't blocked.
If all is well with the inlet valves you should hear a faint humming. This is normal.
If it's a new machine it would still be under warranty, so you should get a Miele serviceman to check out the problem.
Good Luck
Cheers
Nomess
Jan 05, 2015 | Miele Washing Machines
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
http://waterheatertimer.org/Programmable.html#st01
Gene
Water Heater Timers Save Money
Dec 05, 2014 | Hardware & Accessories
Need user manual for THC15A weekly programmable timer
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Din-rail
Add a comment and describe timer buttons.
Apr 22, 2013 | Sourcing Map THC15A Digital LCD Power...
FLBC9 timer not working
That timer is not known.
Make sure light switch is ON and bulb is good.
Check that outlet has power.
Try timer on different outlet.
Check that timer and outlet has matching voltage, and that timer is rated for the type of load you are turning ON.
If timer is programmable, reset timer, and then reprogram and be careful that each ON time has an OFF time, and that days and times do not conflict with each other.
Copy following link and view timers, and download possible manual.
Re-post question with different model number.
Jun 05, 2012 | Hardware & Accessories
How to programme UPM Model ETl30
More information is needed to find manual.
ET130 timer appears to have 6 buttons with 3 buttons on each row.
http://hkm888.com/upm-marketing-et130-indoor-programmable-timer-reviews.html
Review options below:
1) Add a comment and describe timer buttons in detail so I can match buttons with known timers.
2) Open following links and check if manuals for ET525, ET420C, ET420 might have same button and programming relationship.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET130
Add a comment please
Oct 02, 2011 | UPM Indoor Electronic Programmable Plug-In...
How to open little door? I ask help with how best to open the little door with the Woods InWall 7 Day Digital Programmable Timer. I see the notch below the manual override flat button where it appears...
Hello. Yes the door hindges at the top. and unfortunately yes, too much pressure can crack/snap the plastic. This can be minimized by using a precission screwdriver as it will actually fit into the slot and effect the catch itself. a screwdriver that is larger then the slot does not push the tap that actually "grips". I've been told that installing the timer with the door already popped is a benifit. Just take it slow and steady and you should be fine.
Remember to rate this if it helps.
Thank You,
Richard
Dec 17, 2010 | Woods InWall 7 Day Digital Programmable...
How do i take the bread out ?having a dificult time doing it ! thank you
Hi..gently tap the pan on a bread board. Don't tap so hard as to bend the pan...just a couple of quick taps in a few places. Hank
Nov 22, 2010 | Black & Decker B2250 Bread Machine
I need the instructions for a UPM Model 100 indoor programmable timer...
UPM100?
Do you mean UPM RTC100 remote control timer set?
Smarthome usually posts manuals with their products:
See if this is your product:
http://www.smarthome.com/2046/Programmable-Receptacle-Timer/p.aspx
pdf manual
http://www.smarthome.com/manuals/2046.pdf
add a comment if this is not your timer
Nov 20, 2010 | UPM Indoor Electronic Programmable Plug-In...
I lost the installation & how to program infomation.
Woods in-wall 59018 is programmable timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
Woods 59203 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Woods 59337 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59377.pdf
Older style Woods 49556 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
If your timer is not listed, add a comment with description of timer
Nov 15, 2010 | Woods InWall 7 Day Digital Programmable...
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Hardware & Accessories Logo
598 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
