Question about iRiver PMC-120 Digital Media Player
Moving video I have an iriver that I am trying to move video to it. I have a TV card in my laptop and I record some shows for my daughter. I tried to move them to the iriver and no matter how I record it, it tells m I can not play it on the iriver. So how do I do this?
5 Suggested Answers
SOURCE: how to add video's to iriver e10?
The following steps will get you running in about 2 minutes.
1.Download and install iriverter ( 2.
2.Open the Profiles folder within your installation directory (e.g. C:\Program Files\iriverter\profiles or C:\Documents and Settings\User\Application Data\iriverter).
3.Make a COPY of the u10.profile file, and name it e10.profile.
4.Open the newly created e10.profile within WORDPAD NOT NOTEPAD.
5.Change the device from “u10′ to “e10′.
6.Change the dimensions from “320×240′ to “128×128′.
7.Save the file, and close it.
8.Launch iriverter, and select the E10 under Options > Device > iriver.
9.Click the Single Video button.
10.Specify the video file to be converted for the input field, and specify the output file where you want to save it.
11. Once saved drag and drop the video file to the video folder in the iriver directory
Alternatively, the new iriverter also supports the ability to rip and convert an entire DVD, which is just as straightforward as converting a single video.
Click Convert.
Posted on Dec 30, 2007
SOURCE: file check error in
Hi. this is rajesh gp from sivagangai. it is very easy to solve. just long press your iriver menu(M) and goto settings -> advanced -> format. then copy any music files from your pc then enjoy with your songs. []
Posted on Jan 05, 2009
SOURCE: iRiver E100
What you need is a free opensource program called
Use this to convert your movies.
I have the settings at home but I think they were these:
Video settings: frames per second (FPS) 24 or 25, 600 KPBS
format Xvid, container AVI,
Picture settings: 320 x 240 - check the cropper settings you want
In the audio use the Lame MP3 settings no more then 44100 hz (probably 33,000).
If this doesn't work post me a message and I will get you the correct settings.
Posted on Jan 11, 2009
SOURCE: My iriver won't play any video.
Posted on Aug 01, 2009
SOURCE: Can't play videos on iriver e100
how do i play the videos
Posted on Oct 02, 2009
0 characters
1 Points
I record movies on windows 7 media centre and can't play them on my iriver e100 player. I also can't watch mp4 format. What do I need?
Greetings - your IRiver E100 only plays certain .avi files and versions of Windows Media (.wmv) files.
To use your media center and MP4 files you would have to obtain converter software that would convert the files to be compatible with your player. Recording TV shows creates files which are incompatible with the E100 as are MP4 files.
For the TV recordings you would have to do as follows:
Forget the mention of IOS device above - you need to do the same step.
You then have to convert them to files that the player can use. I'm told this software works well and is only $9.95 (USD). Take a look HERE. (I have no connection with this company).
For other files (like MP4 files) you just have to use the converter software I mentioned above and don't need the first step I displayed above.
Enjoy your Video.
May 14, 2011 | iRiver E100 Digital Media Player
DR-1 MAC FINDER does not see it!
I had a similar problem. What i did was to replace the tascam provided cable with another one (similar) from Iriver t30. works wonders. found out that the original cable couldnt plugged in properly to tascam although it did recharge the unit.
Hope that helps.
Jun 03, 2009 | Tascam DR-1 MP3 Player
Cannot put downloaded videos onto iriver e10, suggestions?
why not try the avi format video?
Just get this tool to help you.
1. load your file to Video Sharer
2. choose AVI format
3. click" convert" button.
Then you will get the right format.
Here is the tool for you:
Mar 13, 2009 | iRiver E10 Digital Media Player
Record reservation on Iriver T10 T60
check out the iriver h10 players
May 12, 2008 | iRiver T10 MP3 Player
Iriver h320 freak out!
I have the same problem and Iriver told me the hard drive is shot.
Unfortunately they will not / can not fix it as they have no "out of warranty repair," nor do they have anyone who will do this for them.
Mar 03, 2008 | iRiver H320 MP3 Player
Iriver "USB Connected" screen problem
Before suicide, first consider your daughter ;)
Then make sure the USB ports and cables do not have a lot of dust in them.
Unplug and try it in a different port[also those in the back of your computer]
Make sure you have the driver installed.
Hope that helped, if not, reply with more details.
Jan 12, 2008 | iRiver Clix Digital Media Player
T10 iriver mp3
You Can Download Free MP3 From Youtube By This Site :
If you didn't found Your Favorite Music In Youtube Try These Sites : or
Nov 21, 2007 | iRiver T10 MP3 Player
You have to hit the on button twice to show as connected,then you can manually move files to the root directory by going to the computer ICON on your desktop, finding your MP3 player,then clickto open the file - the find thefile you want to copy or move onto the MP3 and drag it into the MP3's main file NOT the file that says RECORD
Nov 07, 2007 | iRiver H320 MP3 Player
IRiver ifp-700 record error
upgrade the firmware should fix the problem
Jun 26, 2006 | iRiver iFP-795 MP3 Player
iRiver PMC-120 Digital Media Player Logo
Top iRiver MP3 & Digital Media Players Experts
Steven Wander
Steven Wander
Are you an iRiver MP3 and Digital Media Player Expert? Answer questions, earn points and help others
