Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Cannot read the hard disk - Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
  • Seagate Master
  • 27,725 Answers
Figure out whether you need a hardware or software fix.
Look for grinding sounds from your drive or humming that starts or stops.
These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out.
If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix.
Run one of the many software fixes, if you think the problem is related to software.
These programs feature on-screen directions, making it easy for you to progress through them.
If this works, you don't need to fix a physical problem.
Remove the many tiny screws that holds the drive together.
Eventually, you'll get to the innards of your drive.
Be very careful not to bend or force a piece to go where it doesn't want to.
Determine if you've set things straight.
Look to see whether anything was loose inside your external hard drive.
If you have recently dropped it or traveled with it, it is possible that something came loose.
Also check that all the arms and platters are straight and do not appear bent in any way.
If they are bent, straighten them with your hands or pliers.
Put everything back together and check that everything in your external hard drive is working properly.
Try using the external hard drive on another computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb but its not working ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Posted on Oct 30, 2012
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
Why is my hard disk drive indicator light always blinking on my Sony Vaio Laptop? My laptop reads cds and dvds fine, it is just annoying to always see it blinking.
This is perfectly normal. Your hard-disk indicator light is always blinking because your hard-disk is constantly being used by the operating system. Windows and other applications are performing operations in the background which require both reading from and writing to the hard-disk regardless of whether you are doing anything or not.
You only need to worry when the hard-disk light STOPS blinking . . . permanently!
Nov 03, 2010 | Computers & Internet
Will not read any disks except for store bought ones ???
Did you mean hard disk? If so, make sure you buy the right hard disk, there are something different between IDE and EIDE hard disk although their interface look similiar. Go to BIOS to auto detect the HDD if available. The jumper settings on the hard disk can not both set to be master if they are on the same ribbon of IDE interface. If BIOS recognize the hard disk and not reading, there might be something wrong with the disk. Try it on another computer or do some scan on it. It is an option to call Dell and ask them whether they have some hard code of their machine so the machine only read disk with some hidden information too just in case. If the disk is not a hard disk, then there could be standards issue of media too. You can check the specification of your machine and see the detailed version of the interface and see whether you have the same version of standards on your disk.
Aug 23, 2010 | Dell Dimension 4700C PC Desktop
It wont read the disks i put in
your cd drive reads disk, it probably is bad
u should look up hard drives on wikiapedia
May 27, 2010 | HP (PV944A) 160 GB Hard Drive
My acer 7520 opens with an error reading NVIDIA boot agent 249.0542, then reads PXE-E61 media test failure, check cable, PXE-M0F exiting NVIDIA boot agent.
This error message could be a faulty hard disk or a faulty disk controller.
Reseat the hard disk to see if the problem is fixed.
If not go into the BIOS settings and check if the BIOS can detect the hard disk.
If the hard disk is not detected then remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If the this computer cannot detect it as an external hard drive then the hard drive is faulty. Then the Acer needs a replacement hard disk and Windows installed together with the laptop's device drivers and programs etc.
Oct 20, 2009 | Aspire Acer 7520-5324 Laptop
Disk read error alt+ctrl del restart
load optimal or fail save setting then check if it eliminates the problem if it didn't work. reinstall the ide cable of your hard disk check if it eliminates the problem if it also didn't work back up your hard drive for important file, delete and create hard disk file system, partition and reformat your hard drive if this also didnt work replace your hard disk.
Sep 14, 2009 | Microsoft Windows® XP Professional Full...
External hard drive can not be read by the computer
The hard drive was originally formatted for a PC and I was using it with Mac products. I had to delete all the information on the hard drive so that I could reformat the external hard drive to work with my Macbook Pro.
Dec 08, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
Sep 29, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk is read only
format your hard disk with disk manager software. (low level for formating). this software can remove bad sector of your hard disk
Oct 10, 2007 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
85 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
