Question about Motorola Mobility BT51 Battery
Motorola bt51 won't charge. i need the driver software stuff. links would be greatly appreciated.
I've done this before but can't find the same download or anything close to it. Help will be greatly appreciated.
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
1990 crown victoria had valve cover gaskets remove & replaced, and know my won't reverse good, & keeps cutting off
this is a combination of issues from whomever did the work..first, in order to remove the valve covers, all the hardware on top had to be removed, to include some vacuum equipment and hoses, and the shifter link arm on the drivers side of the firewall. if these hoses arent reconnected properly, the running of the car is effected, and if the shift link arm wasnt adjusted when reinstalled, it wont shift right at all.. if the folks who worked on it wont repair it for free(and you are allowed to watch them do it) then take your bill and the defunct car to another dealer garage who will make it right and charge the bill to the former garage..nothing gets my goat worse than someone who doesnt have a clue what they are doing to my car, thats why all my work is done by me, unless I cant do it myself..(which hasnt happened yet) if you know what you are doing, fixing the vacuum system hoses and such(using a diagram from the auto parts store,) will assist the running of the engine, the shifter adjust is eithewr up top on the steering column under the hood, or under the bottom at the transmission itself...put the car in park firmly and see where the shift arm(once loosened ) sets..adjust it to fit as its supposed to be and it should shift right with all gears present..good luck..
Jan 13, 2013 | 1990 Ford LTD Crown Victoria
Misfiring, shaking when in gear, lack of power while accelerating on my 1997 Camaro V6 3800 series. I've replaced alot of stuff already but still can't figure out the problem. Any help would b
tell me what you done is check engine light on go to auto zone they will put a code reader on it for free tell me what codes come of it dont let them sell you anything ok get back to me i can help you im a mechanic
Nov 17, 2012 | 1997 Chevrolet Camaro
How to reset my motorols bt51 with the unlock code forgotten ?
Just type any password until your phone asking PUK code. PUK code is a unique number to unlock your phone if you forget your pin number and can be found from your sim card paper or asking from network provider. With puk code you can unlock motorola bt51 from old pin and you can set new password, but please pay attention when you entering that code don't make mistake for many times. It will not make your motorola unlocked your sim card also locked.
Aug 06, 2011 | Verizon Communications Motorola w385...
I lost my A4tech installer cd so i can't use my A4tech camera.i need a installer for A4tech pk-635m
Here's a link to the A4 drivers site to get the driver you need:
http://www.a4tech.com/driver/A4%20PC%20Camera%20H.rar
The RAR file is similar to a zip file. If your installed unzip utility won't open it, you can download many free ones from the web that will.
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jul 07, 2011 | A4tech PK-635 Webcam
I have a Dell Latitude C610; after initial 'DELL' screen comes up, the laptop gives one 'beep' then black screen and nothing more- power's still there; can get into setup and boot...
This chart details the specifics of what each 'beep code' means. Usually the codes come in series of 2-3 beeps not just one.
http://www.nullamatix.com/dell-diagnostic-beep-code-troublshooting-chart/
You should also make sure the 'dummy' stuff is done, like remove any floppy disks or CDs from the drive if you have one, and remove any USB drives from the laptop as they may try to boot off of them and not be able to. If you've done that, then check the chart in the link for further information. Sadly a non booting, beeping computer isn't a good sign. If I can be of any more help, please let me know.
Hope this response helps you out.
Best of luck!
Jun 22, 2011 | Dell Latitude C610 P3 Notebook
Hello, the battery on my dell vostro 1500 is fully charged, at 65% of its life and passes the dell diagnostic tool, but.. when i take out the plug the battery fails in less than 5 seconds. any help is...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Dell Vostro 1500 Notebook
Does the verizon motorola bt51 need a sim card? and where does it go in?
No Verizon has internal SIM cards that you can not remove. Only GSM phones have removable SIM cards.
Jun 02, 2010 | Motorola Cell Phones
Very short battery life,needs to be charged every 2 or 3 days do not text. phone is used only occasionally. have had a replacement battery bt51 same as original.same results.needs better battery? phone has...
hey there.....most of the motorola phones have great battery life.....but sorry to inform you that your`s doesn`t really belong to that good-battery-life mobile models....so buying new batteries won`t help you in anyway.....so don`t spend your precious bucks on new batteries or repairing your phone without a reason.....well you can try buying a new phone...if it is economical......hope i have helped you...
AND PLEASE VOTE GOOD......HELP US TO HELP YOU BETTER .....!!
Sep 10, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Motorola Mobility BT51 Battery Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
