Question about Whirlpool Duet GHW9150P Front Load Washer
How much to replace dispenser 8540058
My dispenser has quit dispensing. Seems like the little plastic arm is getting stuck
SOURCE: ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Posted on Jan 04, 2008
  • 101 Answers
SOURCE: Softner dispenser
the tube is clog
Posted on Apr 22, 2008
  • 1122 Answers
SOURCE: Ice make problem
I THINK WHAT YOUR SAYING IS YOU HAVE ICE AND WATER IN THE DOOR AND YOUR GETTING WATER IN THE DOOR AND NO ICE,IF THE ICE TUBE IS CLEAR YOUR PROBLEM LIES IN THE INLET WATER VALVE OR THE ICE MAKER ITSELF,YOU CAN JUMP THE WATER VALVE TO SEE IF IT SHOOTS WATER TO THE ICEMAKER,FIRST PULL FRIG. OUT,REMOVE BACK PANEL,TAKE TWO LEADS OFF THE VALVE NOW GO SEE IF YOU HAVE WATER STILL COMING OUT OF THE DOOR,IF YOU DO THESE ARE THE LEADS YOU NEED,FIND A OLD POWER CORD YOU NEED TWO CLAMP FITINGS OR GATOR CLIPS,SLIP THEM ON THE TWO TERMINALS ON THE WATER VALVE ,THEN PLUG THE CORD INTO A OUTLET AND COUNT TO 5 AND UNPLUG,NOW GO TO THE ICEMAKER AND PUT YOUR HAND IN THE WELL AND SEE IF YOU FEEL WATER IF NOT YOUR VALVE IS BAD,IF THERE IS WATER IN THE WELL YOUR ICEMAKER IS BAD,GET THE MODEL NUMBER FROM INSIDE THE FRIG. AND CALL LOCAL APPLIANCES PARTS STORE AND GET THE NEW PART,LET ME KNOW-MIKE
Posted on Jun 26, 2008
  • 531 Answers
SOURCE: ice maker and water dispenser to not work. Just quit!
water valve
Posted on Apr 05, 2009
aasc
  • 1606 Answers
SOURCE: ED25PQ quit making ice. Water dispenser still working
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Posted on Jul 06, 2009
Ice dispenser stuck on crush
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
There is a lever arm on the back of your ice bucket. This arm goes into a opening behind the ice bucket. There is a plastic actuator that raises or lowers to set the dispenser to either crushed or cubed ice.
So, you either have a broken plastic actuator or a bad operating solenoid valve. Both of these components are easily replaced.
Send me your model number which is on the upper inside wall of your fresh food section and I will give you the part numbers of these components.
May 08, 2015 | Refrigerators
Soap dispenser motor turns but gets stuck and bends the arm up away from the dispenser. The washer makes clicking noises and stops. Took the top off to see the problem but then it did not repeat. I am...
this sounds like the same problem I am having. I think you need to just replace that arm which is called the dispenser lever. that plastic piece is too flimsy. hopefully the new parts are made better. I have to leave my top open and move it manually when it gets stuck.
Aug 08, 2013 | Kenmore Elite HE5t Washer
I want to bypass the soap dispenser on my Kenmore HE front loader.
There's no reason you couldn't just put powder HE detergent on top of the clothes before you wash. The water will still run through the soap dispenser
Sep 03, 2012 | Kenmore HE2 Plus Front Load Washer
Ice & water dispenser get stuck, water & is keep coming out os dispenser even after you remove glass
Unplug unit
Remover dispensor housing. Careful not to break tabs.
You will see the white plastic actuator arm.
Follow the arm to where it becomes part of the main support.
Push the arm you will see where the main support is catching on a plastic *** on the rear housing.
Cut or file off part of the ***. so it wont catch.
Reassemble dispensor.
Jan 18, 2010 | LG LSC26905TT Side by Side Refrigerator
Ice dispenser will only give crushed ice; will not dispense cube ice ;I have looked at the auger and chute and nothing wrong there; when I chose cube, it dispenses crushed in both the crushed and cube...
Your selector solenoid is not working. Next to the auger motor there is a selector. You will see a plastic peice in a hole to the left of the auger.....Try to move it up and down. If it won't move it is more than likely frozen in one spot. Try to defrost it. If that does not work then replace the solenoid.
Sep 07, 2009 | Kenmore Refrigerators
Whirlpool Duet sport ht drain and spin seem to be working, but when rinse cycle is selected there is short quick knocking sounds and no action ultimately resulting in an F 30 on the display.
suspect dispenser ..remove top panel dispenser on left side if dispenser arm is binding replace all arms and cams and dispenser motor ..seems to be only fix even whirlpool can't seem to narrow it down to one part
Oct 25, 2008 | Whirlpool Washing Machines
Soap dispenser stuck on LG WM2277HW
Great advice. I used a portion of you plan. Pulled off the top, but since the softener cup is on the right, I only uncliped the 3 clips on that side of the assembly. With those loose, I could pry gently up on the back portion of the assembly lid, and the drawer pulled out.
I also see no need for the cover, other than a measuring device. So removed the screws at the front, pushed the assembly back into the washer, and unclipped the rest of the lid. Once the lid of the tray assembly was off, it was easy to remove the softener cover. The only challenging part was getting the re-closed assembly to go back into the cut-out in the face metal. I got caught a couple times, but getting my hand up under the assemble allowed be to push evenly up on both sides as I pushed it forward into place.
Now the door works fine again. Seems to be a significant design flaw by LG.
Hope the helps other.
Jun 22, 2008 | LG WM-2277HW Front Load Washer
Removing the detergent dispenser
I have the same problem--mine is about 10 years old. To disassemble, looks like you will need to disassemble the complete door--screws around the inside edge of the door. At that price for a replacement dispenser, I will either try to fix or replace the blue arm, or replace the dishwasher. I don't believe its worth putting that kind of money in an old dishwasher.
Lew
Dec 10, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
