Question about Indesit IS70C Electric Dryer
Attatching new heating element
My indesit heating element has packed in, i've ordered a new one. Will i have to take off the whole back plate to attatch the connector (which is inside the back plate) or will i cut and re-connect outside? Please advise
  • 3 Answers
You have to order a new element. and take back and side panel off, to reinstall new one, what ever you do do not cut any wires.
Posted on Feb 13, 2013
Brand new Indesit IDS105 Dishwasher will only complete pre wash cycle, on any setting.
Purchased a second hand Indesit slimline IDS105, to find it would only complete the first wash cycle, at the end of this cycle the LED Would just flash, with the waste pump coming on every 2 mins to empty it. Even after 4 hours it still didn't complete a full cycle.
I looked through the manual only to find that the error code was not explained. I phoned Indesit, after talking to 12 different people, the only thing the useless company wanted to know was whether i had warranty or whether i wanted extended warranty, then after establishing i didn't, they just biffed me on to the next, when i actually got through to a loosely knowledgable person they said they would send out an engineer for you as we are not allowed to tell you what the error code means, I just put the phone down.
So... to the solution, after dismantling the dishwasher i tested every single component, with a multimeter. Through elimination and research i had a hunch it maybe to do with the heating element or NTC Temp sensor. Tested the NTC, perfect. Tested the resistance of the heater this read 0.34ohm near enough should be around 0.29. So i took the mainboard out and tested the relay and this is where my trouble and solution arose. To test the relay i got a 12v battery and the datasheet for the relay, tested the contacts, to here a nice click....Then pop!!! NOOOO i blew the IC that controlled the Relay (ULN2003A Darlington transistor array). I ordered one of ebay (but RS,Farnell sell them for a cheaper price) Unsoldered the blown IC, soldered the new one on.
Put the Dishwasher back together, crossed my fingers, turned it on, and selected programme 2 (Normal wash) and pressed start. 1 hour and 50mins of intense tension later it had completed the whole cycle!!!!!!!! Ive never been so happy!!!
Cheers
Up yours Indesit!
Sam
Jan 16, 2013 | Indesit Dishwashers
Brand new Indesit IDS 105 Dishwasher will only run pre wash cycle, no matter what its set on - factory reset info required
So... to the solution, after dismantling the dishwasher i tested every single component, with a multimeter. Through elimination and research i had a hunch it maybe to do with the heating element or NTC Temp sensor. Tested the NTC, perfect. Tested the resistance of the heater this read 0.34ohms near enough should be around 0.29. So i took the main board out and tested the relay and this is where my trouble and solution arose. To test the relay i got a 12v battery and the datasheet for the relay, tested the contacts, to here a nice click....Then pop!!! NOOOO i blew the IC that controlled the Relay (ULN2003A Darlington transistor array). I ordered one of ebay (but RS,Farnell sell them for a cheaper price) Unsoldered the blown IC, soldered the new one on.
Cheers
Up yours Indesit!
Sam
Jan 16, 2013 | Dishwashers
Need a heating Element for a Master Build Digital Smokehouse Model# 20070106 Serial# GA040923
Since the - - -holes @ Masterbuilt told me they don't sell them, and after extensive seraches on the net, I found a company that is making me one for $37.50 plus shipping. (As of August 31, 2011)
Contact: david@hhelectricmfg.com and tell him you want to order a heating element identical to one he is making for Lelys. (The mountting plate may be a little different, but all you'll have to do is drill new holes in the new mounting plate.
Aug 29, 2011 | Masterbuilt 20070106 Electric Smoker
When we turn the dryer on it doesn't produce heat to dry the clothes, we've even changed the heat settings and the dryer just won't get prdouce heat, but when we tried to look online it stated...
hello matt.... the most common cause of no heat is a burned out heating element. Replace it and you should have heat again. Joe
May 07, 2011 | Dryers
How do i install new heating element
Unplug the machine, remove the back cover and locate the terminals attached to the element, Disconnect them and unscrew the plates that hold the element in place. Remove the element from the holding lugs and take it out. Fitting the new element is the reverse order of the above. Make sure that the socket remains unplugged until you have replaced the rear cover plate. Run the machine and check for leaks
Feb 18, 2011 | Whirlpool Dishwashers
Replacing baking element for GE Truetemp
I just had the same problem. Just remove the rear panel of the range and unplug the two leads. Now go to the two screws inside the oven and remove them. The heating element will now come out and you can insert the new element the same way. Replace the two screws inside the oven and then attatch the two leads in the rear. Replace the rear panel and you are set to go.
Jan 25, 2009 | GE Spectra JBP78 Electric Kitchen Range
Hotpoint aquarius tdc32p not heating up replaced old heating element but still not heating
I had the same problem which turned out to be the thermostat.
You can fix it at home easily with only a screwdriver.
UNPLUG FIRST!
  1. Remove the strengthening bar on the back
  2. Remove the small cover in the centre of the rear
  3. Remove the funny shaped cover from the rear (NOT THE WHOLE BACK PLATE) This will give access to the heating element and the 2 thermostats above it.
  4. Take off the thermostat with a green dot on and look at the bottom metal plate. If it's concave, bang it on the floor until it pops back out. (Seriously)
  5. Re-fit the parts in reverse order and you done!
Nov 08, 2008 | Dryers
Indesit is70c dryer is not heating?
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Feb 28, 2008 | Dryers
My dishwasher is tripping the electric.
Usually time to replace the heating element. The element is sealed inside a metal tube packed with a dry powder to insulate it. If the outer tube leaks (and it only takes a pinhole), the powder gets wet and stops insulating. It only takes a tiny earth leak to take modern trips out. If your dishwasher is one of those where the element is visible in the bottom of the compartment you load the dishes into, replacing it yourself ought to be straightforward. If it's buried in the works, whether you want to tackle it yourself or pay someone else to do it depends on how confident you are. Either way, it shouldn't be catastrophically expensive. A.
Mar 04, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit IS70C Electric Dryer Logo
Top Indesit Dryers Experts
Tim Whalen
Gerard Curran
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
