Question about Toshiba 50H72 50" Rear Projection Television
Upper half of my screen is black and is divided in the middle with colorful lines and the bottom half works fine. Please help me find out what the problem is and if I can fix this myself?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
I have to suspect the model number listed here is not correct as that model is a older rear projection set?
Posted on Oct 30, 2012
SOURCE: Only half the screen is being projected?
i am having the same issue............any solutions??
Posted on Sep 02, 2008
  • 1694 Answers
SOURCE: black lines and menu problem
Check for bad caps in vertical circuit. Solder any/all bad connects. REPLACE vertical o/p IC w/OEM or better quality. I usually use Tosh,Hit,or Pana. 2)Check/replace tactil switch (menu)on front panel.
Posted on Sep 28, 2007
ladywinn
  • 5138 Answers
SOURCE: rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Posted on Feb 05, 2008
ginko
  • 19396 Answers
That is a convergence problem, as posted, it is called horizontal failure, to fix it it is necessary check soldering at the yokes, test horizontal convergence IC, test a couple of capacitors and resistors on convergence circuit, and sometimes the technician may have to replace a pcb inside.
The wole job starts from $80 and usually costs over $200.
To get service you can call the number listed on the owner manual, or look for support on website.
Let me know your location, and the current state of your guaranty if you wnat more information.
Posted on Sep 13, 2008
  • 145 Answers
SOURCE: Vertical line in middle of screen.
no the light engine is fine. it is the digital signal processing to the engine. suggest local service center
Posted on Nov 10, 2009
My flat screen tv has a multicolor bar running down the middle from top to bottom, how do I fix this?
you can fix it by going to tv colour changing option otherwise you read the catalogue.
Mar 27, 2013 | Insignia NS-24E730A12 24" Class LED HDTV
Old Panasonic tv approx 10/12 y/o? -Model TX-28CK1L Serial no ND-0360158 Last night 50% of screen from top to middle "blacked out"--half picture still visable on bottom half. Very bright thin...
The main coupling capacitor feeding the frame scan coils has failed or the output stage on the frame stage has failed due to dry capacitors or dry joints.
Fault finding and components are not a problem and yes it is very repairable. Any technician that knows how television works can repair this standard frame output stage.
I hope you find a good technician.
Dec 30, 2010 | Panasonic Televison & Video
Bottom half of screen sometimes black or bad video
Probably you have to change your resolution settings and what type of operating system are you using?? or you have to get your computer checked out by a professional to be safe.
Apr 20, 2009 | Compaq Computers & Internet
A rectangle with sides parallel to the x-y axes and its left-lower corner at (0, 0) is being painted. The rectangle may be thought of as a flat-screen display with almost infinite resolution; initially the...
It would be "cheating" for anybody to do your "homework" from your computer-mathematics class, unless you submit your answer, saying that an EXPERT on FIXYA did all the work on your behalf.
Apr 14, 2009 | Microsoft Windows XP Professional With...
White screen divided in half with black line
Your ccd imager is defective . You need to replace the ccd imager .You need to contact the service center to get one for your camera .
Jan 30, 2009 | Kodak EasyShare Z700 Digital Camera
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Toshiba 50H72 50" Rear Projection Television Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
