Question about Samsung 220wm 22in Wide Lcd Mon 700:1 .282mm 5ms Spk Blk 220wm
Fix my monitor internal speaker - Samsung 220wm 22in Wide Lcd Mon 700:1 .282mm 5ms Spk Blk 220wm
    Top Expert:
  • Samsung Master
  • 14,553 Answers
The place to begin would be to check the speaker itself--disconnect the wires (if more than one do both) and check it for resistance--8 ohm should read 8 ohm.
If speaker reads good and paper in the cone is not bad you have another problem.
Posted on Oct 30, 2012
How to connect internal speakers on an acer xw233db lcd monitor
Hi Mirta,
If your LCD Monitor didn't come with internal speakers, you will not be able to add anything internally.
10base2
Apr 01, 2012 | Computers & Internet
The speakers do not work on the monitor. What
Chek the speaker continuty with a multimer , Audio Input connector/Cable,next check the Audio out put Chips Voltage +5V pin # 6, If ok then replace the Capacitior at pin # 4 (2.2MFD 25V)..
Jul 10, 2009 | HP w1907 LCD Monitor
Need to turn off internal audio on flat screen to use headset
When you plug in a headset or mic into the bottom or the side of the monitor, this should automaticly disable the internal speakers on the monitor.
May 26, 2009 | Acer AL1717 17" LCD Monitor
DOES THIS MONITOR HAVE INTERNAL SPEAKERS OR DO I NEED TO ACQUIRE EXTERNAL SPEAKERS?
No. If it does not have a connection specifically for your speaker input than there are no speakers, sorry.
Apr 28, 2009 | Computers & Internet
Sony vaio monitor with internal speakers
There should be an audio cable coming out of Monitor, you'll need to plug that cable in the ouput jack of sound card, turn on/increase the volume of the speakers using the switch, slider present on the monitor and then check. you may also consult the manual that came along with the monitor.
Apr 07, 2009 | Sony Audio Players & Recorders
The volume is too low on my computer speakers
Hi, Mark Here, see I can help.
The 1907 does not amplify your sound it will let you control the volume to some degree but not boost the incoming sound.
If you had amplified speakers b4 your sound card requires amplified speakers.
Best two options i can give is.
  1. If it is a desktop you can install a amplified sound card. Hook to monitor speaker.
  2. Unplug monitor speaker &use amplified speakers.
Just so you know laptops use internal amplified speakers. If you decide to install sound card make sure it is an amplified card.
Hope that fixed ya! know not the best news. Need more help comment back. Please Rate.
Good Luck!
Mar 28, 2009 | HP w1907 LCD Monitor
No place to plug in my speakers
Monitor plugs in 3 times?
1] power 2] video 3] sound???
use audio cable from desired speakers rather than for the monitor.
Mar 21, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hp pavilion f1703 17"
The magnets in the speakers will not effect the LCD monitor. If it is an LCD the problem in internal to the unit. You need skematics, trouble shooting skills, test equipment to repair this. If your menu can't fix it then your going to need lots of help with this one. Good luck
Aug 10, 2008 | HP Pavilion F1703 17" LCD Monitor
Internal Monitor speakers
change you your speaker wire or check and make sure it is pluged into the back of the computer in the correct spot
Aug 30, 2007 | LG M1717S-SN Monitor
Samsung 220wm 22in Wide Lcd Mon 700:1 .282mm 5ms Spk Blk 220wm Logo
37 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
