Question about HP Photosmart C5180 All-In-One InkJet Printer
Can't change my ink colors. Took one out at a time and replaced it with a new one. No good Took them all out at time and replaced them with new ones. No good
  • CPCPCP May 11, 2010
    Does the printer has an error? If so, what does it say?
    Sergeant:
  • 237 Answers
1) Make sure the printer is ON when you replace your ink cartridges
Posted on Jan 04, 2009
I change printing inks, but the yellow color does not print note, I've cleaned up several times but to no avail Please do reply with thanks
Ink printers mixed all the colors to print one color. If your hello isn't printing properly than it may be your other colors that need changing. When you open up your printer to change the inks remove you inks and there may be a latch of some sort depending on your model. Remove the print head that was held in place by the latch and clean with a cloth. If this doesn't work you may need to buy a new printer. Print heads are very expensive to replace and not worth the cost for a new printer
Feb 05, 2017 | The Office Equipment & Supplies
The printer does not recognize a new cartridge when I install it. Also, I think the old ink cartridge was still good.
Title:
I replaced my ink cartridge, but the LCD is still displaying "Ink Empty". What can I do? Description: This is typically caused by an incorrect selection made during the LCD prompting after a cartridge is replaced. When an ink cartridge(s) is replaced, the LCD will ask, "Have you removed Blck? 1 Yes 2 No". This question will be asked for ALL 4 colors in sequence, regardless if the color was replaced. If "1 Yes" is NOT selected for the color(s) that was replaced, the LCD will return to "Ink Empty". Do the following to clear the message:
  1. Pull the scanner cover release lever located below the control panel and lift the top cover.
  1. After 15 seconds, re-close the top cover and then re-close the control panel cover.
  2. The LCD will then display Have you removed Blck? 1 Yes 2 No.
    The LCD will display this question for ALL 4 colors (not just the ones replaced). BE SURE to select 1 YES for each ink cartridge that was replaced.
    If 1 Yes is selected, the LCD will then display Change to new (color)? 1 Yes 2 No. Again, BE SURE to select 1 YES.
Note "Change to new (color)?" will only appear if 1 Yes is selected for "Have you removed (color)?" If 2 NO is selected for the "removed" question, the LCD will then move on to the question for the next color.
Jan 27, 2010 | HP Photosmart 3310 Printer
Replacing a cartridge
Title:
Oct 11, 2009 | HP Photosmart 3310 Printer
Printer not recognizing the new color cartridge
turn back your old color ink -> do cleaning page few times -> replace new one if the problem persist -> change color ink if the problem persist again -> change cartridge
Oct 01, 2009 | Canon PIXMA MX310 All-In-One Printer
Flashing light check print cartridge
You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
Jan 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
Black won't print
I have this same model printer and had this same problem. I solved it by running the cleaning cycle repeatedly (30 times or more). It nealy drained the black cartridge, but they're cheap compared to a new printer ($100 for the mfc240c that replaced it). Press the ink button to the left of the display. Select "test print" and "print quality from the menus, then hit print. After printing, the display will ask if quality is ok. Press 2 for no. It will ask if the black was ok, press 2 for no, if the color looks ok, then press 1 when it asks if color is ok, then press 1 when it asks to start cleaning. In a minute or so, it will beep and tell you to press start. Once the sheet prints again, repeat the same sequence. I didn't even wait for the display, I would just press 2,2,1,1, each time it printed. At first the black section was blank, the one dash appeared, then two or three. I gradually gained on it until I had most of them working again, then let it set overnight and ran a few more cycles the next day and it finally all started working.
Jun 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Aug 11, 2007 | Brother DCP 130C All-In-One InkJet Printer
Color doesn't print before and after printhead replacment.
No, its not possible. The problem is likely the ink has dried in the purge unit or one of the small tubes going to the waste pad. The new printhead is the fix for the ERROR 41. The problem is there is sometimes other things that go bad, purge unit being just one example. One of the biggest problems with inkjets is that consumers leave their printers alone for long periods of time and the ink dries and clogs the tiny hoses inside. Even the ink cartdriges are just ink tanks, I have replaced those many times and have seen bad ones that just won't flow, replaced the inks and it works fine. You also have to put in the id# for the printhead after you replace it. Did you do that or get the instructions?
Sep 28, 2006 | Brother MFC-3220C Plain Paper Inkjet Fax
HP Photosmart C5180 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
