Question about HP Compaq nx6110 PC Laptop
Wont stay charged
Even when it is plugged in all of a sudden the laptop shuts down
  • 86 Answers
Your issue with your portable seems to be an ac adpter problem based from my experience.
After replacing ac adpter and issue is still present, the problem is with the power supply and/or motherboard which needs to be replaced.
You may need to call your technician for servicing or send it to your OEM's service depot.
Thanks and good luck! =)
Posted on Jan 03, 2009
Gateway laptop shuts down instantly when unplugged but fully charged.
I have come across connection issues on the battery terminals. Make sure the brass contacts are not tarnished or bent. Have you tried another battery?
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
When i start my fujitsu notebook it appears and suddenly shutdown
Are the fans and vents free of dust? Unplug, remove battery, Try to reseat the Memory mods., plug in, reboot. When it shuts down, does the Battery charge LED stay lit?
Jan 19, 2013 | Fujitsu AMILO D-7820 Notebook
My laptop powers up but the screen stays black then it shuts itself down
It could be the CPU fan... Best to have it looked at by a service center...
Aug 12, 2012 | Toshiba Computers & Internet
My toshiba 205 cds wont power on, it goes from green to red?
If you plug in your adapter, is the charge light on? If not you need a new AC adapter (the part that plugs into the wall all the way to the plug that goes into your laptop jack) or the jack is bad - they wear out mechanically or even break the solder joints.
If not then the machine is trying to start from battery, the battery is too weak and it shuts off and gives a red. If the light does stay on even if you wiggle the plug into the machine then you may have a bad charging circuit on the motherboard inside. In that case you may need to find a reputable shop (NOT Geek Squad, they will only want to sell you a new machine).
Jul 02, 2010 | Computers & Internet
I have a panasonic toughbook cf-48. It was working and then all of a sudden it shut down and won't turn back on. I thought it was that the battery wasn't charging, so I bought a new battery. When I looked...
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 25, 2009 | Panasonic Toughbook 48 Notebook
Laptop suddenly shut off and will not turn back on
Sometimes the voltage regulator in the battery hit a point where they fall below a certain efficiancy % they have to operate at. Once they fall below that % you must replace them, even if the battery is 100% charged. Its usually a good idea to pick up a new charger as well with a new battery since they are known to die as well. Make sure you check the socket in the back where your charger plugs into the laptop to make sure its not loose or cracked. Sometimes the plug will crack off the motherboard and not make good enough contact.. But regardless of that it should atleast turn on if the battery was charged and good. Best bet, new battery. Every 2 years you should get a new one.
Jun 04, 2009 | Toshiba Satellite M45-S269 Notebook
Battery indicator on even after turn off the laptop
Reset the battery.....remove battery from system...boot while your adapter is plugged on....shut down..reinstall the battery......
if this doesn't help..
go to Control Panel>>>>>>Power Options and view setting ..........what does the system do after being switched off options
keep me posted
Nov 17, 2008 | IBM ThinkPad T40 2373 Notebook
Attempting to load but suddenly shut off..
It sounds like the laptop was in a screen off state (happens when it is left on but not used for a while).  When you pushed the power button it went to shutdown, and notified you that someone (you) is still logged on.  Any unsaved work could be lost, hence the warning.
Five minutes later when you went to switch it back on, the laptop coincidently must be low on battery, to the point where it will not stay on, and exhibits the problem you are experiencing now.  Try plugging in to power and make sure that the battery is charging, and try again.
Nov 06, 2008 | EliteGroup ECS A535 Notebook
Problem cause:
Do diagnose your Laptop try to change your battery or adapter if you have some backup device
Sep 22, 2008 | Dell Computers & Internet
My 6030 has suddenly shut down!
it shutted down because (maybe)
of the folowing reasons:
1.) Error
2.) You have overloaded it,
3.) Full Memory.
try removing the battery (5 mins)
the put it back again.
then press on..
if it wont want to start.
charge your cellphone.
then try pressing the on button
Nov 02, 2007 | Nokia 6030 Cellular Phone
HP Compaq nx6110 PC Laptop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
