Question about GE JVM3670 Microwave Oven
Everrything works - food does not heat up - two fuses OK
Everything seems OK but food will not heat up. Checked the fuses and they are OK. Electrical "burn" smell from area of magnetron.
  • 1 more comment
  • c_ferekides Feb 02, 2009
    Yes!
  • Anonymous Mar 29, 2014
    Its not heat the food
    And the magnetron heat highly
  • Anonymous Mar 31, 2014
    doesnt heat the food at all. fuse look ok.
  • GE Master
  • 9,086 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
So verify that is working before you take the unit apart.
We have a sound clip of what a microwave should sound like when the cooling fan and all are working here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned , it's probably fine)
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though it is bad!)
If you need further help, please write back with the results of your tests.
Posted on Jan 03, 2009
  • William Miller
    William Miller Feb 03, 2009
    Once you've looked all this over, if our solution proved correct, we would be grateful for a FixYa rating if you think we've earned it.
    Thank you & good luck.
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
JVM16331BB005 over the range microwave oven will not heat everything else works ok
That is a sign the magnetron has shorted and is the most expensive part to replace.
Apr 28, 2012 | GE Microwave Ovens
I have a Whirlpool GH5176XPS microwave and everything seems to work fine except that it does not heat anything. I have checked all the fuses and they are fine. Any suggestions?
The problem is more than likely a bad magnetron, "heats food" the other two considerations are the high voltage capacitor and diode.
Mar 31, 2011 | Whirlpool GH5176XPS Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM3670 Microwave Oven Logo
286 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
