Question about Ridgid Generator. 5700 Watt Yamaha 301cc Portable Generator
I changed the oil four times and its still milky
I think the carb is messed up but im not sure...it will start and run for a few min then it dies and the oil is almost white its so milky...i have changed it for times and its still milky....help me please lol
    New Friend:
  • 22 Answers
If your oil is milky you are getting moisture in the crankcase. Does this unit set outside? make sure your crankcase vent is clear.
Posted on Jan 18, 2013
I have water in my carborater now its not running well
First drain the fuel tank , fuel lines and drain the oil while its draining , put a fan on the wiring and dry it out. Take the plugs out of the engine and turn the motor over this will force any water that's left in the cylinder out .Water that's got in to anyother parts of the engine will come out with oil Add oil to the engine and turn it over again ,without the plugs in .Let it sit for 5 minutes .then check the oil to see if there's water in it ( If there is it will look like a white milky substance ) if there is u need to drain it and start all over again u will have to keep doin this untill there is no white in the oil . Now once u have done this re-install spark plug,add the gas , then try to re start . If it starts. Leave it to run for a good few mins BUT don't rev it .
After it runs for a few mins turn it off re-drain the oil and change the filter .run again for few mins, turn off check the oil again for. A milky colour if there's none yippy uv done it if it dosent start u need professional help good luck
Jul 07, 2014 | Cars & Trucks
Ran snowmobile out of gas now wont start
try a couple of shots of Ether to get the Air out of the Line between CARB and Tank, seen it a few times also it will clean out the Jet in the Carb , put some Injector Cleaner in the tank to get rid of Varnish IN the Carb should take a few tries but within Half hour should run like New
Dec 17, 2013 | Cars & Trucks
Hi all i have a jonway spray 125cc scooter and have issues getting it running. I can start the bike up, and let it run, but then it dies on me and i cant start it up for the next 20-30 mins. If i start...
Did you put the fuel filter in in the right direction??
Also give the fuel bowl a few good sharp tap's to be sure the float shutoff isn't jaming
Jun 28, 2017 | Motorcycles
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
Will not stayed cranked. changed out old fuel, fuel filter, changed oil.
The Virago's have a tendency to clog up the carb. quickly due to sitting for a short amount of time, say a month or 2. Try and run some SEAFOAM in the carb. Remove the fuel line from the tank and force the seafoam into the carb with a turkey baster. Run the carb.s dry as best you can, force the seafoam into the carb. and let it sit for a day or so.Then try and start the bike off the seafoam, it will run and make a lot of smoke. Then hook the tank back up and see if that did the trick. Sometimes it will sometimes not, you may have to pull the carb.'s and clean them by removing the bowls and soaking them in a pan of the seafoam or something similar.
Feb 20, 2011 | 1997 Yamaha XV 535 Virago DX
Starts full choke dies out runs for a few min at half choke dies out at no choke. noticed tank is full of air bubbles when running
First, you will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Jun 17, 2009 | Poulan Pe550 Gas Edger
Power loss & Fouling Plugs on an 75' IH Scout
Sounds like you are on the right track, except that the vacuum advance won't give you the radical symptoms you have. I'd take the carb apart and clean it out. likely the power valve is gummed up and could also be the needle & seat are worn. Make sure you find a good rebuild kit before taking it apart though...the gaskets are likely dried out & will break.
After all this time it's possible that your float maybe sinking. I've seen this happen before. If you have one of those litle generic fuel pumps likely it cant make more than 5psi on it's best day, so I don't think it will blow the needle off the seat.
Yes...change your oil & plugs after youv'e finished and don't drive it with fuel in the oil.
Apr 20, 2009 | 2007 Jeep Scout
Ridgid Generator. 5700 Watt Yamaha 301cc Portable Generator Logo
77 people viewed this question
Top Ridgid Saws Experts
John Trevino
Jim Thurston
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
