Question about True T-23G Commercial Refrigerator
I need a manual for a True T-23g commercial refrigerator
Cannot find the defrost timer?
  • True Master
  • 1,230 Answers
3 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: where is the ballast in a true commercial coke
It depends on the manufacturer of the specific unit you have, but most of the flouresant light ballasts are installed on the top of the unit either on the back of the top illuminated name panel, or on the actual top of the unit. I have seen some that had the ballasts installed at the rear of the unit and even down in the lower section where the compressor is located.
You'll need to look around as each manufacturer has different specs for their particular units and without the wiring diagram, it is difficult to provide an exact answer to your question. If you remove the cover plate to the bottom section or look on the back of the unit, you might find the wiring diagram that could include a schematic and a line drawing showing the placement of all major components. With a little effort on your part, you should be able to find it.
Posted on Jul 13, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: T-23 Refrigerator quit cooling.
Look in the back see if that compressor is running. It is balck kinda ball shaped. It pumps freon so to make the refrigerator cold. If it runs but do not get cold then it needs freon.
Posted on Feb 18, 2010
Pluggd in unit. Turned on, not cooling. Adjust cooling knob. Will shut off unit, but turned on will not cool.
True - Document Download
www.manualjos.xyz/Category/troubleshoot/true/freezers
What does the do mean on the lae electronic control panel of a t23fg true fridge ... Hello my freezer is not cooling properly and the defrost timer is . making a loud ...
Aug 17, 2015 | True T23FG Commercial Refrigerator
IM-23G
Give a photo of the board or of the code plate.
May 27, 2014 | True Food Service Equipment True...
T-23g light not working
Did you make sure the switch was working? Ours went out and it was the switch.
Aug 18, 2012 | True T-23G Commercial Refrigerator
Wiring diagram for defrost termination switch
If its been working for years, the wiring is correct you just have to figure out, if its working now. I hope you have a meter, if the timer is advancing going in and out of defrost, then you need to check that the contacts are working, the timer cover will give you that information, with power, on check between the contacts with the meter, and if the contacts are closed, you will get 0 volts, if its open you will get line voltage 120 or 208 examples. Good luck
Jul 03, 2011 | True T-49G Glass Door Commercial...
True t49g side by side not defrosting
True's T-49G is not equipped with a defrost timer as it is a medium temp unit, so I would suspect the temperature control may be defective. Part #800393 is commonly used for the True T-49G, though it's best to check verify with model number and serial number. It could also be as simple as adjusting the temperature dial a little bit. The target temperature range is around 36 degrees Fahrenheit.
May 31, 2011 | True T-49G Glass Door Commercial...
What initiates the defrost?
Hi and welcome to FixYa I am Kelly.
Your defrost cycle is controlled by a mechanical defrost timer similar to a spa timer
Download this manual then see pages 13 and 14 for locating and setting the defrost timer.
http://www.mbm-service.de/mbmTechTwo/True_/GDM-9+/Service_Manual.pdf
There are 3 different types of GDM units. NOTE the one 2 and 3 door timer locations on page 13. There are all in different locations.
Also see page 109.
If you need service or technical help:
TRUE MANUFACTURING TECHNICAL SERVICE
1-800-325-6152
Thanks for choosing FixYa.
Kelly
Sep 26, 2010 | True GDM-23 Refrigerator
True T-23G Commercial Refrigerator Logo
52 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
