Question about Briggs & Stratton Automatic Home Standby Generator System 7 Kw /6 Kw
Generator will not turn off on auto - Briggs & Stratton Automatic Home Standby Generator System 7 Kw /6 Kw
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
Mar 01, 2015 | Generac Electrical Supplies
Why does my generator start constantly?
if a lightning strike was anyplace close (30 yds) it's a safe bet your gonna have to replace the control board in generator also Id have a qualifyed tech ck out your auto transfer switch ,I bet he''ll find that you fried your coils on your switch too , do that before changing control board cus if ya hook up a new one to a bad coil ya just bought two of them
May 24, 2014 | Kohler Electrical Supplies
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Auto idle does not work propertly on makita g 6101 generator
The battery charging is also a load. If the battery is not well charged or old it may need about 60 - 120 W to charge, which is not "Idle".
Jun 24, 2010 | Makita G6100R 5800 Watt Generator
When I have it on it stays on high idle speed. When I push the auto idle it will not change the speed to normal. It idles at high speed all time.
If you have anything plugged into the generator, consuming any electric, it will run at high. It must run at high speed to generate 120V. It will only idle if your turn off the load.
Feb 13, 2010 | NEC Mitsubishi MGE 4000 Generator ROU...
Electric start is not working. How do I start it with out the auto start?
turn the auto starter off, you should have a key switch like a car or a push button. if not and, if your unit is equipped you'll have to use the pull starter. good luck.
Oct 16, 2009 | Briggs & Stratton 6200 Watt Electric Start...
Engine cuts out when hot
every generator has an auto-shut down system that turns the engine off when over heated..u can dislocate the wire coming out of the engine and into the on/off switch...and then it till never shut off unless u tell it to....
but be carefull!!!!!!!!!!!!!:when u dislocate it...u r turnning off the auto-shut down system...so if the engine over-heats.. it will not shut down...
if u have any further questions email me at sal_kh_sab@yahoo.com
Jul 13, 2009 | Coleman Powermate Powermate 5000W...
Auto idle on a reddy rgh11000 ie will not idle down
This sounds like the idle control solenoid has become misadjusted. To check that this is the case, locate the throttle lever and follow it back towards the governor arm until you find the solenoid. Start the generator and switch on the idle control while watching the governor arm where it passes near the solenoid, if the arm snaps back and forth you probably have a bad adjustment. To readjust the solenoid loosen the jam nut on the core of the solenoid just enough that you can turn the core by the square bit on the end. Adjust the core 1/4 turn or so at a time until the governor arm stays in position when the idle control is on, then turn idle control off and make sure that the governor arm goes back to the full throttle position. You may have to fiddle with the adjustment a little until you find the right spot. Tighten the jam nut back down and you're good to go.
Carl
Dec 09, 2008 | Honda 6370C - Parallel Power Kit For ...
Briggs & Stratton Automatic Home Standby Generator System 7 Kw /6 Kw  Logo
63 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
