Question about RCA D52W136D 52 in. TV/DVD Combo
D52W136D convergence
    Top Expert:
  • RCA Master
  • 14,553 Answers
Common issue in this model---look to see if the option for convergence still appears in the menu---if not you have a bad part right at the flyback causing this---a kit of 3 parts is available (tvparts.com).
Set is also for this issue prone to bad solder connections at the flyback and right around it that will cause convergence issues.
Posted on Oct 30, 2012
I have a 52" projection tv went blank the other night came back on and now is showing a double picture
Tv have a problems known as a convergence problems,it dead.The tv convergence board.The 2 STK convergence ICS and some or all the resistors are dead.These parts are dead,must replaced to solved the covergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Cant find convergence in setup
There are three small rectangles sqaure boxes cap fuses parts(FL231) the one in the middle is dead.Replaced the one in the middle located right side near of the big black block of plastic call FBT.U know how to do soldering and have the equipments?Try website like Ebay.com to the cap fuse part(FL231) fuse.After the cap fuse(FL231) is replaced the Convergence well return,ur tv back to normal.
May 28, 2010 | RCA D52W136D 52 in. TV/DVD Combo
RCA D52W136D 52 in. TV/DVD Combo dvd does not play
did you try to get a dvd cleaner to clean out your dvd player.
Feb 13, 2010 | RCA D52W136D 52 in. TV/DVD Combo
RCA D52W136D 52 inch has no green.
most likely its the Green CRt drive board you should be able to get a new CRT Drive board for about 30.00 at the following link. www.tvrepairworld.com
Aug 14, 2009 | Televison & Video
The sound went out while watching a program on the set.
It sounds like the IC that controls the sounds has gone. Once upon a time they used to start with the letters TDA and other sets of letters that would make them instantly recognizable but nowadays it could start with anything so unless you know what you are looking for call out a technician. Good luck.
Sep 28, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Hello sjustinh,
It sounds like your color processor may have gone bad or at least the circuitry connected to it. To solve this problem you will need a schematic, a digital storage oscilloscope, a signal generator, and a multimeter. Now if you don't know what these devices are and do not have a background in electronics, I would suggest that you take the TV set to a qualified TV repair person. I am not trying to put you down or anything its just that this problem requires that you open up the set and using the schematic trace down the signals that control the LCD screen and find out the condition of the signals that display green. Since green is the result of the algebraic addition of red and blue, you may have a problem in the circuitry that controls that function.
I hope this helps,
Thank you,
Shuttle83
Sep 18, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Green looks brown
Maby its not tuned in the channel right
maby its the way the picture is
or try
turning the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Finding servicemanual
Hello plantain,
try www.servicemanuals.net or www.manualsparadise.com
Sep 09, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Picture WAY messed up!!
Go to menu, and under video or picture, go to advance setting and then go to convergence. This TV should be equipped with and automatic convergence adjustment. Just follow the instruction on you owners manual. If this does not fix it, it means that your convergence chips are shot, and you will need to have a train repairman fix it.
RCA D52W136D 52 in. TV/DVD Wont turn on
Does the standby light flash in a set pattern? Some tv have a error code system which pinpoints the fault by flashing the standby light a certain number of times. Other than that my best guess would be a fault on the power supply or a fuse blown internally. Good luck.
Apr 08, 2008 | RCA D52W136D 52 in. TV/DVD Combo
RCA D52W136D 52 in. TV/DVD Combo Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
