The aerial port does not work.
When I connected my aerial lead for the very first time after coming off Sky, after using the "Source Button" I could not get interference let alone a picture. As this the first time the tv has been used for terrestrial tv, I wonder if the aerial socket has ever worked.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It is possible the tuner or antenna connection is bad---If you can call up the menu with the remote set needs to be switched from cable etc to air or antenna and channels programed------not on the rear input connection but for the tuner in the set (presume it has a tuner if antenna connection of any type is there.
Posted on Oct 30, 2012
3 Suggested Answers
  • 77 Answers
SOURCE: PS2
By an aerial do you mean a converter?
For the neew TV's you don't need one. Just plug it in using A/V cable (yellow is video, red and white are audio). Be sure you take note of which input you are plugging it into on the TV, and then use your TV's remote to change the video input (usually will be labeled video or TV/Video on the remote) to the one you plugged the PS2 into.
Posted on Jan 06, 2008
  • 8457 Answers
SOURCE: acoustic solutions lcdw22dvd95f. tuner problem
Without the DTV digital converter box.Ur tv tuner have statics video come out to the signal at all?Yes it the converter box not the tv.
Posted on Mar 17, 2010
My cello tv won't tune in at all. Every time I try auto tune it goes through the process of tuning then says no signal.
Auto tune would be for the old analogue TV system I believe. Does the aerial connect through a box or direct to the TV? The Sky box should connect through scart (very old) or HDMI which you just need to choose the right input for. Look for a button on your remote for input or an icon that looks like a screen with an arrow pointing into the middle.
Feb 18, 2018 | Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Can I record programmes with a Sky box as the input source? I do not have a tv aerial, just a sky dish.
No, it can only record from its own tuners via an aerial, not from a scart connection..
Aug 07, 2015 | Humax PVR9300T HD DVR
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Lost our freeview. New TV in bedroom (Sharp LCD, LC-19SH7E-BK), which has freeview and was working fine. However, we set up a magic eye so we can have SKY (which we can now use through channel...
if you have connected your sky box as per instructions, putting the aerial coax to it and a fly lead(as in a male to female coax as used on a vcr to tv) from the output to the tv's aerial input, then disconnect the aerial from the sky box and put it back to the tv. The skybox will weaken and even loose the signal.
Feb 14, 2010 | Televison & Video
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Sky
You do not say which breed of sky you have.. old analogue, digital, sky + or sky HD if you have old analogue then you may have to connect through aerial connection, digital will have a scart socket to connect to your tv, sky + will have the same and finally the cream of the crop sky HD will have hdmi in addition to scarts.
The very least you need to do for a digital picture (not to be confused with hi-def which it isn't) is connect through scart lead then unless it auto-switches to scart input upon switching on sky use your tv remote to select the ext input 1, 2 or 3 etc (some remotes have a button called source for this some call it input etc) select each ext input until you find the one your sky is connected to
Oct 12, 2008 | Televison & Video
Linking televisions
Use the aerial outlet from your sky box and run the aerial lead to your additional tv. There should be two of these spare if you are using a scart lead for your main tv.
Feb 18, 2008 | Televison & Video
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
