Question about Refrigerators
How to tighten door handles on Frigidaire side by side refrigerator model number FFHS2611LW
SOURCE: Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Posted on Oct 10, 2008
SOURCE: Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
Posted on Sep 30, 2009
  • 29 Answers
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
SOURCE: The handle on my refrigerator door (Admiral side
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Posted on Dec 30, 2009
  • 4 Answers
SOURCE: Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Posted on Jan 24, 2010
How do I tighten door handle on frigidaire model jsi-26
Good Morning Chris, thank you for your inquiry!
From my understanding you need to tighten the door handles on your Frigidaire refrigerator. I was unable to locate any information on your model JSI-26. Without the model number I would be unable to provide you with proper instructions on how to tighten your door handle. Could you please provide me with your model number? You can locate your serial tag (which lists your model number) on the right hand wall of your refrigerator. With that information I would be able to assist you further. -Matt
Aug 01, 2015 | Frigidaire Refrigerators
I have the Frigidaire Model BFHS2611LMO Side by Side and the handle on the right side is very loose. I took off the rubber seal on inside of door but dont see any screws to tighten. How do I tighten
The model number is actually BFHS2611LM0. The handles have keyhole openings that fit over the pair of screws (near the top and bottom of the handle) on the outside of the doors. Try pushing the right side handle forward and down to lock it back onto those screws. If that doesn't solve the problem, push the handle up and then lift it off the screws. Then tighten the screws a bit (or replace them if they have stripped threads). Then replace the handle over the screws and push the handle down. Do not overtighten the screws; that can damage the door components. The manuals is available from Frigidaire's support site: http://b2b.frigidaire.com/support/manuals.asp . The support page for your refrigerator is here: http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=BFHS2611LM0&User=&Search=Search . The parts diagram shows how the handles are attached; it's the last link on the support page.
I hope this helps.
(please replace the door seal properly to ensure that your refrigerator maintains it's efficiency. http://www.searspartsdirect.com/frigidaire-refrigerator-parts/model-BFHS2611LM0/1428/0165000.html has another copy of the parts diagrams with the parts for sale.)
Jul 28, 2015 | Frigidaire Refrigerators
How to read model number FFHS2611LW?
Hello friend, thanks for the post!
Please help me understand the question you are asking. Is there something specific you are searching for within the model number? Or are you referring to four or five appliances having the same model number? I look forward to your response. -Matt
Aug 29, 2014 | Frigidaire Refrigerators
How to tighten handle on frigidiare fridge
I understand you are seeking some assistance on how to tighten your door handles for your Frigidaire refrigerator that is listed under model FFHS2611LB. This is not a typical DIY job I would recommend you have a technician come out to the home to tighten the handles. -Matt
Jul 29, 2014 | Frigidaire FFHS2611LB Side By Side...
How to tighen handles?
Hello Friend, that's a great question!
In order to provide you the correct instructions on how to tighten the handles of your Frigidaire refrigerator I will need your model number please. You can typically find the serial tag (which lists your model number) inside the cabinet, on the left/right side wall. Thank you! - Z
Jul 13, 2014 | Frigidaire Refrigerators
How to tighten the door handles
Good Morning Friend,
I understand you want to know how to tighten the door handles on you Frigidaire refrigerator, model# FFHS2622MB3. Below is attached a link to your manual. Use manual number 808353502, and you will find handle installation instructions on page 9 of the manual, with diagrams. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
Show how to tighten screw on door handle on a frigidire model ffhs2622m
I found the manual on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. If for any reason you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 09, 2013 | Frigidaire FRS3R5EMB Side by Side...
Tighten door handle on frigidaire side by side refrigeratoar
Hello - Generally speaking, Frigidaire refrigerators do not have a way to tighten door handles. I would suggest contacting a professional due to either the screws are not secured all the way through or they may have to take multiple layers off to correct the issue.
Oct 29, 2012 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer door handle is loose
Usually those handles push directly up to come off the pegs. You really have to "lean in" to push the handle against the door and then try to slide it up. Once you get it off, you can tighten the studs (or whatever hook/clip thingy they came up with) and slide it back on.
Feb 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator door handle is loose how do I fix it?
some come off when you pull straight up if there are no visible screws. then tighten the screws on the inside of the handle that fasten into the clips on the door.
Jun 12, 2009 | Refrigerators
Refrigerators Logo
989 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
