Question about Honda Em5000 Em7000 Generator Service Repair Manual 61z1100
How to start a honda em5000s generator - Honda Em5000 Em7000 Generator Service Repair Manual 61z1100
  • 512 Answers
I have Honda generator 4100 with remote start it will start and run untill u let off botton light on remote switch went out how do dy pass switch
PDF]SERVICE MANUAL - Electric Generators Direct
www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Hond...
associated with operating your NAC portable generator, following the precautions listed below will assist you in .... For detailed engine information, refer to the Honda Engine Shop Manual. Note: ? ..... (e) Do NOT remove the diodes or de-solder the wires attached to the diodes. (f) Ensure you have ... NDK-4100YE. WIRING ...
Aug 04, 2015 | Honda Electrical Supplies
What do I check? i have a honda eu2000i that starts and runs but no generator power
The internal monitor is sensing a load does a load make it change tone? Check the 12 v output and see if it is loaded.
Kevin H
Sep 08, 2014 | Honda Eu2000i 2000w Generator
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
Have a Honda 5000s generator. 2-3 x during the years, when started, the engine runs well but no electricity gets generated. The shop says that there are buildups of something within the unit that need to...
Hi Ken, How old is the generator and is there more info on the model number, like EM5000S. What they probably are referring to is a hazing where the brushes make contact with the stator. The brushes are made of very soft composite of carbon/graphite. If the stator hazes over then it becomes non conductive. If you take a rectangular pink pencil eraser and cut it to the size of the brushes you can push it in one of the brush openings and with the spark plug removed clean the stator by pulling the recoil starter. Also a little rubbing alcohol will help to dissolve the haze. If your generator is brush-less then it's a whole different story.I recommend that you read this article on flashing a generator. http://www.endtimesreport.com/dead_gen.html The drill method seams to be the easiest and fastest way to get the lights back on.
Good Luck,Michael Burke
Nov 06, 2011 | Coleman Powermate Powermate 5000W...
Have a Honda EM5000S generator issue. Will start easily, run for a few seconds, then cut off. Problem just started. Checked spark plug, air filter, fuel line. All fine. Any ideas would be appreciated.
I sounds like it might be the low oil shut off. it has a bypass that allows it to start but then cuts off after a few seconds. even if the oil is fine the sensor may be bad.
Aug 10, 2011 | Mi T M MiTM 6000 Watt 13hp Honda generator
Where do you remove the Ground Neutral bond on a EU6500is generator? I need to do this to hook it up to a transfer switch as per Service Bulletin #20.
Page 39 of the current owners manual for the both EU6500 and the EM5000 generators indicate that there is not a neutral ground bond on these units.
Per the wiring diagram, the ground pin on the outlets is connected to the frame ground of the generators (on both generators). To have grounded electrical service, a bond wire would connect the generator frame to the ground terminal on the transfer switch. The ground system from the breaker / distribution box (usually to a ground rod) then serves as the electrical ground for the generator, as well as the balance of the rest of the system, satisfying NEC requirements.
See Page 39 in both manuals:
EU6500 EM5000
"The system ground is not connected to the AC neutral
wire. If the generator is tested with a receptacle tester, it will not show the same ground circuit condition as for a home receptacle."
Sep 22, 2010 | Honda Transfer Kit for EM 5000iSAB and EU...
No power at outlets
there are fuses located on the gen..check those
Nov 17, 2009 | Honda Mmd 5000 Watt Electric Start...
Honda Em5000 Em7000 Generator Service Repair Manual 61z1100 Logo
265 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
