I have a Hitachi 42 inch rear projection TV. The other day, the color went almost like it looked 3D and then the screen just shut off and the power light on the front just blinks red.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Look for the model number (43fdx01B etc) and from description I suspect maybe the convergence chips----confirm to me actual model number and I can tell you how to proceed.
Posted on Oct 30, 2012
ctf1800
  • 4402 Answers
SOURCE: No red color in picture
Red tube bad.
Posted on Dec 05, 2007
  • 41 Answers
SOURCE: the Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Posted on Apr 16, 2009
  • 250 Answers
SOURCE: I have a 42 inch LCD rear projection Sony TV. I
There is most likely a problem with the lamp or lamp driver. You would think the television would have a way or telling you though.
Posted on Oct 01, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi 51f500a rear projection tv screen looks 3d
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks with fins on them.
When the chips are installed a white grease called heat sink compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Posted on Oct 30, 2009
Testimonial: "You truly are an expert! Thanks for the advice, don't think it could've been explained any better!"
  • 597 Answers
SOURCE: KP-65WS500 65 in. Rear Projection Television: 65 inch sony projection TV, just had the convergen...
call tech support with # of blinks
Posted on May 22, 2010
Screen is scrambled. Working fine until I unpluged the TV one day. Is it a fuse?
If it looks 3d or warped its a convergence problem
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself
Apr 22, 2011 | Hitachi 51F500 51" Rear Projection...
51 inch projection- can't read words clearly,
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 14, 2011 | Hitachi 51F500 51" Rear Projection...
My hitachi rear projection tv has one of it's colors out of alignment almost like it's been bent because it causes the blue color to be out of alignment in a curved fashion across the screen the tv worked...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 02, 2011 | Hitachi 50FX20B 50" Rear Projection...
Hey there recently my screen just went haywire and i am seeing double and the second picture is red in colour,also the bottom of the screen is curved....what causes this and is it worth fixing?
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 23, 2010 | Hitachi 50UX57B 50" Rear Projection...
Picture looks 3d and a little blurry
•Screen looks 3D
Aug 17, 2010 | Hitachi 51F500 51" Rear Projection...
Blue streak across the top of the television and colors are reflecting making it look 3d
•Screen looks 3D
Jun 26, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My projection tv looked like it was in 3D for a few minutes then went blank
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Hitachi 51F500 51" Rear Projection...
Colours are out
•Screen looks 3D
Mar 10, 2009 | Toshiba 42H81 42" Rear Projection...
42" Rear Projection color issue
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2008 | Toshiba 42HDX82 42" Rear Projection...
No Picture No Sound
were the colors looking 3D before the set shut down? If so chances are its the convergence amp ICs and thats what has shut your set down. Let me know if you need anymore info.
Mar 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
