Question about Emerson LC320EM9 32 in. LCD HDTV
Are the wires connecting the power supply board to the other large board sautered to the other large board or plugged?
  • Tyler henson Oct 29, 2012
    i need to know because if it needs sautered i cannot do that i will have to pay someone, however; if it is a plug that connects them i can buy the board and replace myself
    Top Expert:
  • Emerson Master
  • 14,553 Answers
Yes, almost every modern set all the boards interconnect via plugged wires but if Emerson good luck finding the part you need.
Posted on Oct 30, 2012
  • 1 more comment
  • Tyler henson Oct 30, 2012
    all i kind find are used boards off ebay, i really dont know how often these go out but the one i found is 40 dollars, would it be worth fixing, or will i find myself in this same situation in a few months since i am buying a used board?
  • SD Tech
    SD Tech Oct 30, 2012
    You are taking a gamble that it fixed the set first--compare to buying a new set which could be a smart move--I do not like Emerson products for the most part.
  • Tyler henson Oct 31, 2012
    well true but the 40 dollar gamble vs a 400+ guarantee, think ill take the gamble, thanks tho
I have a oil less compressor 120volt,2.5amp,60hz,1phase,100psi tank that has 3 wires a black,white,green..the black an white connect to a panel inside the plastic cover of the compressor,the green isn't...
Connect green wire to any steel surface so that the body of the compressor is grounded.
Otherwise, join another wire to the green wire and extend the length to a surface that can ground the compressor body.
For safety, a motor must always be grounded.
To test the ground, connect power to compressor, and test hot black wire to steel body of compressor and to steel housing of motor ... if there is a positive ground the test will show 120V.
Tape tester leads to wood sticks for safety... do not touch anything made of metal... stand on completely dry surface... never stand on bare ground... stand on boards and wear dry shoes.
Gene
Aug 15, 2014 | Hardware & Accessories
Wiring diagram for whelen 96 series edge matrix board
Constant power to large red wire, then power to the green or blue wires usually power strobes
Apr 07, 2012 | Peripheral Enhancements EDGE Tech Corp...
The screen has gone blank but the sound is alright.
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help in solving the problem.....
Aug 08, 2011 | LG 19LH20 19 in. LCD HDTV
No picture
Often there are fuses on that board - one or more. Check those.
Good luck in solving the problem.....
Jun 10, 2011 | Element Televison & Video
Wiring coming from the power suply at top is burnt and i am in need of information to connect it it to plug. It is the wiring on the top of the board beside a smaller plug. Any help would be appreciated.
The power supply board is dead.That the board,where the power a/c cord plug into the board.Any connections of wires or connectors are burns.Power supply board is dead,might be effected to the other boards in the tv, that could be damaging to other boards too.But tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement first,see what happen.
Sep 22, 2010 | Dell W2600 26 in. LCD Television
How do I replace a power supply on a Compaq Presario SR5110NX Desktop PC
you can purchase a power supply from any computer store *********** board supports both standard IDE and Serial ATA connections, so you want a power supply that does SATA power as well. Unplug the power cord from the back of the computer. remove the cover from the case and verify that there is no green LED on the board that is lit up (if there is, there is still power on the board). unplug all connections from the current power supply, including all drive power and the large 24pin plug (actually a 4 pin plug that is combined with a 20 pin plug) on the board, then unplug the 4 pin plug near the processor. careful that the 24 pin plug and the additional 4 pin plug near the processor have latches on the side. Remove the 4 screws that hold the power supply in and remove the power supply, install new supply and reinstall the 4 screws. first plug in the 4 pin plug that connects with the 20 pin, the 4 pin plug has no latch, it is held in place by the 20 pin plug. then plug in the 20 pin plug and the 4 pin next to the processor. then plug in the drive power to all of the drives. Install the power plug at the back of the system and you should see a green LED on the board when you insert the power. replace the cover and power the system up.
Apr 03, 2010 | Compaq Hewlett Packard Presario SR5110NX ...
I have novice computer experience when it comes to internal repair, but i was working on a E-machine T6211 and after cleaning out all the dust, it turns on, the fans run, no led lights come on, the cd rom...
OK, it sounds to me like you have one of two issues going on.
When you clean out dust near the mother board or system board you need to be VERY careful. There are small diodes that stick up from the system board that are very sensitive. So, if they get hit or the small wires that connect them to the board get severed, you system board could get damaged.
From your description, you are getting power to the system board, but there are not signals going from the system board to any of the drives. Inside your computer, there are several ribbon cables plugged into the system board. Make sure that all the cables are plugged in securely at both ends. Also, there is on large collection of wires coming from the power supply that go to a large, white rectangular plug that plugs into the system board. Make sure that this is securely plugged in. There may be another small white square plug that also plugs into the system board and provides power.
If all the cables are secure, check the power cables as well as the ribbon cables, and your hard drive and CD drives are not responding, I would guess that you have a damaged system board.
Do this with the computer powered off and unplugged.
Please check this and see if it makes any difference.
Let me know.
Brian
Feb 25, 2010 | E-Machines T6211 PC Desktop
NO POWER AT POWER SUPPLY BOARD EVEN AFTER REPLACING FUSE.
If the mains cord has only 2 pin plug, you can plug it the other way to see if the mains cord has an open circuit at one of the wires. It is not uncommon to find open circuited mains cord for a large appliance like a TV. The degaussing circuit causes a surge in current consumption when you switch on the TV from cold.
Mar 14, 2009 | RCA P52926 52" Rear Projection Television
VTECH V.SMILE
I had the same problem. Power would not come on. Here's what WORKED on my system. Everytime you change the cartridge, pull the power cord out before removing the cartridge. Put in the new cartridge. plug it back in, press the reset button and then turn it on. It works 90% of the time with this procedure. When I say pull the power cord out, I mean from the system, not from the wall.
Jul 17, 2008 | Vtech V.Smile TV Learning System
Psu blinking green light, no power
I read all the solutions, followed the manufacturers instructions exactly, replaced the cmos battery and nothing solved the problem (blinking light on PSU after a power failure and no startup at all). I had ascertained that the PSU was intact by disconnecting all the PSU connections to drives and motherboard at which time the PSU LED stopped blinking and was constantly on.
Just before throwing my computer away I decided to follow the instructions listed by "guest" to unplug the power to the motherboard and then with the power supply back on to plug the cables back into the motherboard. No only did sparks not fly, but it started up and ran perfectly! Many thanks to "guest."
Oct 31, 2007 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Emerson LC320EM9 32 in. LCD HDTV Logo
32 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
