Question about Panasonic NN-P295SF Microwave Oven
Nn-p295 waveguide cover broken on ends - Panasonic NN-P295SF Microwave Oven
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: pansonic model nn-p295 over the range microwave oven
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 23, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The door release on my Panasonic NN-P295 microwave
OUTDATED POST - PLEASE REMOVE
Posted on Nov 23, 2011
Nn p295 microwave stops after 3sec
You could have a problem with the inverter board or magnetron. If it shows a code like "H98", then it's probably an inverter issue. To test, go to:
Http:://educypedia.karadimov.info/library/Inverter.pdf
Nov 13, 2016 | Microwave Ovens
Can you replace the waveguide in a model NN-SN756B Panasonic microwave oven?
Generally, there are no user serviceable parts in a microwave oven due to the dangers of exposing yourself to microwave radiation. There are special screws that can only be removed by technicians who have the right tool.
However, I did find this.
Microwave Oven Repair Guide Replace wave guide cover
Oct 28, 2015 | Panasonic Microwave Ovens
The Mocrowave Panasonic NN P295 stopped working. Not a single light is on. I checked the power at the receptacle - is OK. May be the fuse inside the microwave was blown. How can I replace the fuse. Where...
Did you recently have trouble with the cooktop lights?
Sometimes when the cooktop lights blow or are inserted or removed while the oven is still plugged in, the filaments can short, causing a surge that damages the controller.
They can be repaired. More details here.
Nov 05, 2011 | Panasonic NN-P295SF Microwave Oven
Where is the thermal switch located
If your model is NN-P295, then the service manual is here.
You can order Panasonic parts from
Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Most microwaves have a thermal cutout or thermostat on the magnetron, on the top of the cooking cavity, and often on the floor of the oven or above the bottom cover.
Jul 13, 2011 | Panasonic NN-P295SF Microwave Oven
My panasonic microwave model NN T99)SAF is now missing a part. The part is on the inside of the microwave. It is a thin flat piece that is a cover over an opening for a fan or something . . .it is about 4"...
That is called the ceiling cover, also known as the waveguide cover, stirrer cover, or spatter shield.
It will definitely need to be replaced. It provides important protection for the magnetron.
You will need the following parts:
B20554U00AP ceiling cover
A90804U00AP canoe clip
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 30, 2009 | Panasonic NN-T990SA Microwave Oven
William E. Miller
prototech@usa.net
Jan 23, 2009 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-S541BF (2001)
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
The best place to order Panasonic parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Dec 21, 2008 | Panasonic NN-S541 Microwave Oven
Problem
This is the waveguide cover and it should not be broken. You have to replace it.
Jul 19, 2008 | Panasonic NN-S540BF Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
60 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
