Question about Dell Inspiron Computers & Internet
Dell inspiron e1545 screen goes black when using battery power
Dell Inspiron E1545, I get a Black Screen when i use Battery Power Posted by Guest on 10/29/2012 Details Dell Inspiron E1545 operates fine under ac power, but when I unplug or start with battery power the screen is black, i have checked update and even did new os, but still black screen when using battery power. Just did full system restore and still the same results
  • Dell Master
  • 7,627 Answers
If the battery is good, mine died after 4 years, check the settings in Power Options, look for dim when on battery power. Increase the % to Max or 100%. see what happens. Still have problem consider replacing Battery.
Posted on Oct 29, 2012
leecom72
  • 4806 Answers
SOURCE: Dell Inspiron E1705, Faint Black Screen on Battery Power
the first thing i would do is do a bios update for the machine whilst using AC power, that may well iron the problem out, if not then there is a problem with the laptop itself i.e. a power drain, sizzling and popping noises is not good at all and could damage the machine further, remove the battery and check the connections on the laptop, dust and hair conduct electricity, it could be as simple as that, it is also a known fact that some lithium batteries are faulty and have been known to blow up whilst in use.
Go to the laptops support website to find out if they have been having problems with batteries and if there any returns proceedures
best regards
Posted on Nov 17, 2008
Geekman
  • 32281 Answers
SOURCE: My Dell Inspiron 1300 wont start
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 10, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
ruben_barrer
  • 117 Answers
SOURCE: Dell Inspiron 1721 - screen goes black
check the light on the power supply that you are hooked up to. before you plug it into the laptop see if there is a green light when the plug has power from the wall. if you see a green light on...good. it means the power supply is responding correctly so far. if you get no green light, then your transformer is out in the psu. if you get a green light and plug in to the laptop and the light goes out, one of two things could be going on. first there could be a short in the psu like the previous tech said, the second more serious issue could be the power controller on the motherboard. they've been known to go out. like the tech before said. try another power supply if you can. but if you are getting a green light on the power supply before you plug it in...there may be another problem with it.
good luck!
Ruben
Posted on Jul 19, 2009
  • 4 Answers
SOURCE: Inspiron 1525..black screen. The screen is black
or screen probably is burned...
or inside crystals are broken..
u have to buy a new laptop
Posted on Apr 11, 2010
Dell Inspiron 6000 turns on but does nothing else.
From the description the hard drive has failed or windows has corrupt files. Unplug power supply from laptop and remove main battery, press and hold power for 2 minutes to remove residual voltage. when finished install battery and power supply now power up.
May 03, 2012 | Dell Inspiron 6000 Notebook
Dell inspirion 1300 screen goes black
Turn OFF the laptop, unplug the ac adapter and remove the battery.
Without the battery and ac adapter, hold the power button for 10 secs.
Put the power sources back and turn ON.
Mar 01, 2011 | Dell Inspiron 1300 Notebook
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Dell Inspiron 1501 laptop with AMD 64 processor: Black Screen
Go to Control Panel/Power Options and check the settings. It's probably set to shut off after a period of time.
Oct 31, 2009 | Dell Inspiron 1521-JB Notebook
My screen on my dell inspiron 1520 has gone black
You've lost your desktop display.
The first thing I would do is to start the computer in safe mode. Once there, do a system restore back to the time that it worked.
I would also, just to be safe, do your disk management tasks like checking your hard drive for errors and running defrag.
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Screen goes dim while in use
If you're using the battery, change the power saving settings.
May 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 700m
I have a Dell Inspiron 5100. I've had it for about three years. One day it did the same thing, no power, no fan, nothing. I replaced the power supply with a 350 watt unit from Office Max. I spent about $40 and I'm using my Dell to send you this response.
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
