Question about Russell Hobbs 13153 Iron
My Russell Hobbs Slipstream steam generator iron has stopped steaming, how can I rectify this fault?
I have tried the white vinegar but this has not solved the problem
3 Suggested Answers
  • 244 Answers
SOURCE: The iron heats up, but when the steam generator
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Posted on Jul 20, 2011
SOURCE: I have so far seen
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Posted on Aug 21, 2011
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
Aug 04, 2011 | Russell Hobbs 13153 Iron
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Jul 20, 2011 | Russell Hobbs 13153 Iron
I have a Bosch Steam Generator Sensixx B25L that has suddenly stopped producing steam. The iron gets hot so that bit is ok, help, I have a huge pile of ironing!
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Jun 01, 2011 | Irons
When i iron brown liquid is coming out has ruined a lot of white tops cannot get it out
This is caused by deposits that are in the water you are using. Empty the iron and fill with a 50-50 solution of Vinegar and water. start it up and iron on some rags for about 5 minutes ho the highest steam setting use the sprayer liberally. Empty the iron and repeat until you see no mor deposits on the rags. Then use only distilled water in the iron.
Apr 19, 2011 | Russell Hobbs 14033 Iron
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
I am trying to find a replacement filter for the russell hobbs steam station Model RHTC102ST
where can i purchase a filter for Russell Hobbs steam station model rhtc102st
Mar 19, 2010 | Irons
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Russell Hobbs 13153 Iron Logo
99 people viewed this question
Top Russell Hobbs Irons Experts
Jim London
Jim London
AZBen
AZBen
richie46
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
