Question about Makita Drills
Spares Parts cordless model: BDF451 part needed: 'plastic' gear shift sleeve located in the gear assembly Paul
  • 22 Answers
If the part you need is part of the actual gear assembly you will need to buy a complete gear assembly, check this parts diagrams http://www.ereplacementparts.com/makita-bdf451-drill-driver-parts-c-97_106_107_3676.html
Posted on Apr 11, 2014
I have lost the top to the filter on my Dyson, DC59 GT9-US-FJC3318A. Will you help me get another?
Variant Parts - Dyson
https://www.dyson.com/parts/variant-parts.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Dyson parts for DC59 Animal. Carbon fiber brush bar $22.99 Replacement Carbon fiber brush bar assembly for your Dyson DC59 vacuum cleaner.
Dyson Vacuum and Fan Replacement Parts - Official Site ' Dyson.com
www.dyson.com/parts/select-variant.aspx?category=Cordless
  1. Cached
Find spares and replacement parts for your Dyson vacuum or fan. Select your machine model to see a full ... Dyson Hard DC56. Dyson DC59 Cordless Vacuum ...
Spare parts for DC59 Animal - Dyson
https://www.dyson.co.uk/spares/variant-spares.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Image of Soleplate rollers Soleplate roller pack £1.50 · Image of Wand assembly Wand £55.00 · Image of Crevice tool Crevice tool £10.00 · Dyson Combination ...
Dyson DC59 / DC62 Animal Vacuum Cleaner Parts
www.partswarehouse.com/Dyson-DC59-DC62-Animal-Cordless...s/6871.htm
  1. Cached
  2. Similar
Dyson DC59 / DC62 Animal Cordless Vacuum Parts, Accessories, & Repair Schematics. Free Shipping Available - PartsWarehouse.
Genuine Parts and Accessories for the DC59 Dyson Cordless Vacuum ...
https://www.dysonspares.ie/index.php?route=product/category&path=66_285
  1. Cached
Genuine Parts and Accessories for the Dyson DC59 range of Cordless Vacuum Cleaner. owerful handheld vacuum which boasts a brushless switched reluctance motor. It is small, light and powerful. Dyson DC59 Google Search
Dec 26, 2016 | Top Vacuums
My 1987 D21 4x4 jumps out of gear on 2nd gear...is it a linkage problem?
Could be a worn or bent shift fork in the tranny preventing the hub and sleeve for 2nd gear from fully engaging. Too, that hub and sleeve could be worn out. If it grinds going into 2nd gear, the synchro for that gear is worn out , which can result in the wearing out of the 1-2 hub/sleeve assembly.
Feb 11, 2015 | Cars & Trucks
Parts manual sander model 315.11751
Confused:
"Problem with Riding Mowers & Garden Tractors"
"Parts manual sander model 315.1175"
"Need large plastic driven gear for dust impeller"
So is this a mower/tractor? ... If it's a manual sander, why does it have a gear, driven by plastic, for a dust impeller? Who is the manufacturer of said ambiguous item?
Have you contacted the manufacturer?
Sep 02, 2012 | Garden
Gears slip when drilling in all speeds although 3rd is the worst it applies to al setting settings as well screw, drill, or hammer. i've taken it apart the gears and visible parts are all fine none are...
As long as the shifter is fully engaging then you will need to replace the transmission. It comes as one complete assembly. Here is a diagram with part numbers. The trans is part #125433-9 (reference number 12) and is just over $53
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/BDF451
Jul 12, 2011 | Makita BDF451Z 18V Lxt Lithium Ion 1/2"...
Replace the window regulator on the drivers side
Please don't forget to rate! Thanks!!!
Motor & Regulator
  1. Remove the front or rear carrier assembly.
  2. Slide a hammer handle between the window guide and carrier assembly until the hammer handle end presses on the gears of the carrier assembly.
  3. Unfasten the bolts (1) and remove window regulator.
To install:
NOTE:By removing window regulator motor, gearing shifts, it is not centered
  1. When installing window regulator motor, the gears must be aligned until the window regulator motor is centered again.
  2. Attach and tighten the bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
  3. Carrier assembly with window regulator, installing:
    • For replacement part carrier assemblies, the gearing is secured in place with a cable tie.
For replacement part carrier assemblies, the gearing is secured in place with a cable tie (1)
  • Slide a hammer handle between window guide and SF so far until hammer handle end presses on gears of SF.
  • Remove the cable tie .
  • By removing window regulator motor, gearing shifts, it is not centered.
  • When installing window regulator motor, gears must be aligned until window regulator motor is centered again.
  • Attach and tighten bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
  • // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 23; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
    Dec 09, 2010 | 2001 Volkswagen Cabrio
    I need a replacement steam wand sleeve
    I called them about the same problem, they can only sell the entire wand assembly, not the teeny washer that I lost. $35. If I knew what it looked like I wonder if I could find something at a hardware store.
    Jun 06, 2009 | Saeco Starbucks Sirena Espresso Machine
    Plastic sleeve on shift linkage cable is broken
    You cannot take the sleeve off. It comes with a new cable. Shift cable is enough for any parts man to know what you need. Generally this item is a dealer part.
    Mar 26, 2009 | 1996 Chevrolet C1500
    Gear shift assembly
    This is a common problem, I had the same issue, mine completely broke off. You can buy the new sleeve with a new rod at the dealer. The replacement is quite simple. You need to remove the upper and lower covers for the steering column, then drop the sterring column with by removing the four bolts. There are four bolts that hold the sleeve in.
    Jul 20, 2008 | 1993 Ford F150 SuperCab
    Drills Logo
    192 people viewed this question
    Top Makita Drills Experts
    epangan29
    John Trevino
    Are you a Makita Drill Expert? Answer questions, earn points and help others
