Question about Sony KDL-46NX810 46 in. 3D LCD TV
Sony Bravia KDL-46NX810 shuts off with 3D input only
My Sony Bravia KDL-46NX810 shuts down with a 3D input signal only. With a regular 2D input signal it works fine. After it shuts down, the Stand By LED blinks 6 times. About 3-5 seconds before shutting down by itself the screen dims a bit and I noticed the screen blinking a bit in the upper right corner. I checked the Diagnostics Screen (Display,5,VOL -, Power), and it shows a Backlite error. I visually inspected the Backlight Inverter board and everything looks normal. However I cleaned it a bit, removed dust, etc and connected everything back without the back cover of the TV and turned on my 3D BlueRay player. When the first 3D image appeared I noticed a noise coming out from the power supply board (I guess). It is a rattling noise, and I believe it comes from one of the transformers. So I am thinking the problem is not necessarily the backlight inverter board, but it might be related to the power supply. Any hints? what component (s) might be faulty in the power supply? Or is the backlight inverter draining too much current form the power supply?
  • Cesar Sanchez Oct 30, 2012
    I made some other tests with my set and the same problem happened when I activated the 3D Simulation feature
  • Cesar Sanchez Nov 03, 2012
    I called Sony Customer Service and after an hour conducting the same tests I had conducted myself they told me my TV had to be serviced.
    Top Expert:
  • Sony Master
  • 14,553 Answers
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Posted on Oct 30, 2012
Ho do I check and replace inverter board for sony tv kdl-60ex720?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 19, 2015 | Sony Bravia Kdl-60ex720 60" 3d 1080p...
My sony bravia tv keeps shutting off
in this case you tv main board is defective because this is a temperate error please replace main board
Feb 28, 2015 | Sony Bravia Kdl - 46Hx800 46 inch 3D Led...
While watching my sony KDL-46NX810 TV its suddenly shut off and starts blinking 3 times red standby light. Please have me inform, what this error means and how to repair or what to replace on my...
Hi Gerard,
3 flashes of the led light on most KDL series is a power supply malfunction. To confirm the error code, lets access the self diagnostic screen by following the steps below.
Unplug the unit from the outlet for 30 minutes and then plug it back in and check if the symptoms remain the same. Wait until the led light stops from flashing and then press in rapid sequence the "Display", "Channel 5", "Volume (-)", "Power" button key on the remote control. Self diagnostic screen will be display. Let me know the result.
Jdvillanueva
Nov 09, 2011 | Sony KDL-46NX810 46 in. 3D LCD TV
SONY Bravia 3D TV won't recognize my SONY 3D DVD Player
I don't have the answer....but I just got the same problem. DVD player senses no 3D TV though my Bravia KDL certainly is. Did you ever get it fixed?
Sep 14, 2011 | Sony TMRBR100 3D Sync Transmitter for 3D...
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Picture shuts down during install
ther eis a setting in your menu for shut down with no signal turn that option off and you should be all set
Dec 27, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KDL-46Z4500 Captions
Try pressing the 'Display' button on top left of TV remote.
Jan 31, 2009 | Sony BRAVIA KDL-46W3000 Television
How to improve picture quality sharpness?
PICTURE QUALITY IS USUALLY A FUNTION OF IT'S SOURCE. GARBAGE IN GARBAGE OUT.
IF YOU HAVE COMCAST OR SATELLITE AND IT IS NOT HD, YOU NEED TO HAVE AN HD SIGNAL FOR THE BEST PICTURE. THE BEST INPUT IS THRU THE HDMI INPUT. IF YOUR UNIT HAS A GOOD PICTURE WITH YOUR DVD UNIT, THEN THE HAVE A SIGNAL SOURCE ISSUE.
Dec 14, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KDL-46NX810 46 in. 3D LCD TV Logo
146 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
