Question about Clarion VX400 Car Video Player
I am unable get into the menue of the stereo for thesame reason it asks for a password and at the moment i do not have the remote ijust ordered one so what suggestions do u have
Can I fix my vizio e472vle? Or do I need to purchase a new tv? Any Idea what i would need to repair the problems listed below (flciker of menu and smart functions).
Follow these steps to reset your TV:
  1. Unplug power to your router.
  2. Perform a Clear Memory or Reset to Default on the TV.
A. Using the VIZIO remote, press the Menu button.
B. Use the Arrow buttons on the remote to highlight System and press OK.
C. Highlight Reset & Admin and press OK.
D. Highlight Reset TV to Factory Defaults and press OK.
E. If you have not manually reset the parental code, please input 0 0 0 0 when it asks for the password.
F. Highlight Reset and press OK.
G. Wait for the TV to turn off.
The TV will turn back on and the Setup App process will begin.
  1. Plug power back to router.
  2. Perform the setup process and reconnect to your network.
Jun 02, 2017 | Vizio Televison & Video
Cogeco code s0900
The receiver was unable to tune to the selected station for some reason.
From the Cogeco website...
If you see a "One Moment Please" error on some channels that provides a reference code starting with S, it means the receiver was unable to tune to the particular channel(s). If you are also experiencing poor service on your analog channels, this could be related to a signal issue.
You should:
  1. Check the connection to the digital receiver and make sure it is firmly secure.
  2. Bypass any splitters or other equipment between the wall outlet and our TV.
  3. Check if the cable line has been damaged.
You can also try resetting your receiver by unplugging the power for 30 seconds (keep in mind that the menu/guide will need to be downloaded again).
If the "One Moment Please" errors continue, please contact us, as a service call may be required.
Hope this helps!
Oct 30, 2013 | Televison & Video
Ijust wanna boot my laptop and to remove BIOS sytem password
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore...
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Jun 27, 2012 | Dell Computers & Internet
Been accused of misbehaving on Shufflepeople twice now for absolutely no reason. Can you please help me?
Unfortunately, you will need to contact the company that owns that game in order to address the issue. It seems there servers may be experiencing some technical difficulties at the moment, so I was unable to find their contact info.
Regards,
G33k
May 07, 2011 | Computers & Internet
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
The buttons on the front of the tv are locked how do i unlock them. i bought this tv from a friend and they dont have the code
Hello there,
The default code is 0000 but this only works if a code has not been set. You will need the RCA remote or a universal remote programmed to work with the TV to enter the code.
If a code has been set and forgotten you can reset the code by pressing VOL+ on the remote and the CH+ button on the front of the TV simultaneously. However, you will still need a remote to set a new code. When asked for a password, simply enter a new code - I'd suggest setting it back to the factory default 0000.
The child lock then needs to be disabled from within the on-screen menu. This option is located in the Preferences menu and is called FPA Lock. This should be set to OFF assuming you don't wish to use the parental control feature. You may be asked for a password when switching FPA Lock off, so it's better to change the password first, as above.
Please try this and post back if you are still unable to remove the lock or if you don't have a remote.
Hope this helps.
Regards,
BElectric
Mar 05, 2011 | RCA TruFlat 27F520T 27" TV
PC to television hook-up
It's possible yes.
You'll need a RGB cable and a 3.5mm stereo minijack cable. Set resolution to 1024x768 or 1360x768. Plug from PC to INPUT 6 on the back of the TV. Press menu on the remote, go to SETUP and go to INPUT SIGNAL. Change the resolution to 1024x768 / 1360x768. Or, go to the AUTO SYNC. and select YES.
After all that, Press PC button on the remote and it should work like a computer monitor.
May 30, 2009 | Sharp LC-32SB23U 32 in. LCD TV
No stereo sound output from audio out jacks. Speaker sound is OK
Make sure that the set is not in mono mode. It should be in the audio menu or you may have an audio button on the remote control.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 23, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
New - parental lock LOCKED and password will nowr work can't use DVD
Problems with V-Chip/Parental Controls
The rating limits don’t work
• For rating limits to take effect, you must lock V-Chip settings to activate them.
I don’t remember my password and I want to unlock the TV
• If you forget your password you can reset it. Enter 5898 as the password and then change it
to a new one.
Dec 06, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Clarion VX400 Car Video Player Logo
20 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
