Question about Dryers
My roper dryer no longer buzz during cycle selection. Furthermore, when I press the start button, I can hear power going to timer (w/cycle selection) but dryer wont start. What parts should I test/rep
RED4440SQ0
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Check the door switch. You should hear a click when you press and release it. I replace these switches all the time. Here is the part should you need it.
Posted on Oct 30, 2012
exspert
  • 55 Answers
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
Posted on Jan 21, 2008
IFIXALL
  • 868 Answers
SOURCE: Dryer will not start when start button is pressed, makes a buzzing noise
Mode land serial number?
Posted on Jun 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Dryer Won't Turn On
2b3eba2.jpgThis fuse mounts on the rear blower housing. If lint builds up in the dryer this puppy will melt and shut down the dryer door circuit. It will be just as if you opened the door. Simply replacing it will get the dryer going again but failing to properly clean out the dryer will result in more fuse failures.
Posted on Dec 31, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
SOURCE: I have a roper dryer red4440sq0 that will not turn
I bought this dryer 2 years ago. After exactly 1 year, the heat stopped working completely. It turned out to be the Thermal Cutoff device ($20). Then, just last week, the thing stopped working completely. It took me all of 10 minutes to determine that it was the Thermal Fuse (http://www.appliancepartspros.com/part_details.aspx?part_id=3132867), just by using my continuity detector on the two terminals. I unhooked the terminal wires, stuck them together, and the dryer turned on fine. They count on people buying new dryers completely whenever one of these dinky little parts made by child laborers in Asia fail. The fuse is $10 at the site I just linked.
Posted on Nov 17, 2009
My Kenmore Elite dryer has power & you can select a cycle, but pressing the start button does nothing. The timer flashes and makes a buzzing sound.
Check door switch plunger, it protrudes into the switch to make contact and may be broken, if OK, check for broken door switch. Order parts from repairclinic.com
Sep 18, 2015 | Kenmore Dryers
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Mde9316ayw
sounds like u got a bad motor. try holding the lid or door switch in while u press the start button. if u give the tub a little help and it starts going then it is the motor.
Jul 25, 2013 | Dryers
My dryer is not working and only making a buzzing noise when i press the start button
is the buzz more like a growl? if so, you probably have a bad motor. if it is truly a buzz, then try turing your timer to a different cycle. if the problem continues, replace the timer
Jan 22, 2011 | Whirlpool LER4634J Electric Dryer
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
I switch the dryer on the light comes on as normal
HI. the filter is fine. Anytime you can hear a buzzing, That is behind the timer module, this will indicate that there is a serious issue concerning the timer mechanism. This device is damaged. The actual timer motor is failing. This will not allow for proper advancement of the cycle selected, in this case. The entire timer control device will need to replaced asap. Once replaced, the unit will operate correctly.
Oct 30, 2009 | Candy CDC266 Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
