Question about ASUS K Computers & Internet
My AC adapter (ASUS K53E) will only charge the computer when it is at a certain angleor when i push really hard.
    Novelist:
    Champion:
  • 233 Answers
It is most likely that your laptop dc jack is loose or dead. Just replace it or repair it. If you are good at computer, you could do it by yourself as the following instructions:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Posted on Oct 31, 2012
  • ASUS Master
  • 7,627 Answers
Seems the laptop connector has been disturbed, pull, tugged on. A connection most likely is loose in the machine(motherboard) or could be a defect in manufacturing. If new return it or ask the manufacturer for a repair/replace. They will most likely suspect customer damage. BE PERSISTENT, don't take no as an answer. Good Luck
Posted on Oct 29, 2012
3 Suggested Answers
MalKontent68
  • 748 Answers
SOURCE: New AC Adapter Will Not Charge Battery/Operate Computer
Most probably static electricity killed some circuitry inside your laptop.
Posted on Nov 12, 2009
  • 206 Answers
SOURCE: AC Power supply overheating for ASUS eee PC
If the pc is fully charged, dont leave it plugged in. Mine gets hot but I've experienced ones that were hot to-the-touch...I'd say be careful leaving it on charge when you are not at home.
Posted on Jun 09, 2010
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
Nov 29, 2013 | ASUS A3Ac Notebook
Asus k53e help
it looks like you have no operating system is currupt for what ever reason was the F9 boot to install you backup operating system this may have been deletet you could reinstalled a new OS via cdrom the os .
Your next option could be reinstall
Jun 23, 2013 | Computers & Internet
My asus k53e charger port is broken well it still works when I put some force on it but it seems as if the charger port is pushed in and the charger can't reach please help I need to use my laptop and
Hi,, this is a very simple problem but the fix for it is or can be very hard. depending on your skill set you can try to attempt the repairs as I will describe below, but you should really consider getting it professionally repaired.
The problem is the charge port. Quite often the solder holding the contacts is broken and causing it to short out and sometimes the pins in the port are broken as well.. This fix is as simple as re soldering the port or replacing it..
1.) Follow the instructions on this likn to disassemble the Laptop and get to the charge port. http://www.ifixit.com/Guide/Disassembly+guide+for+Asus+K53E+laptop./10166/1
2.) re solder or replace the port.
General Disclaimer
Please note based on the information given i have made my suggestions, This can be wrong as I'm not there in person to verify it therefor i can make no guarantee that is the problem. I strongly suggest you have this problem professionally looked at.
Dec 27, 2012 | Computers & Internet
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
How to light up keyboard on asus k53e-rbr9 laptop
ive had this laptop for a few months now and unfortunately it does not light up. i really dislike that it doesnt. what i have to do is tilt the screen so the light reflects to the keys. but you can buy a little light up usb light for relatively cheap on ebay. just look up "keybord light"
Jun 11, 2012 | ASUS K53E-RBR9 15.6" Laptop
My ASUS P4T533-C won't turn on
This is really a common problem with computers these days. It may be caused by a number of reasons like a faulty charging system, faulty battery or anything burned out on the computer's system board. But in this scenario, i would suggest the following
1. Remove the battery and connect the laptop with the AC adapter only and see if it will respond.
2. Remove the AC and re-connect the battery and try to turn it on
3. If the above two do not work, then consider changing the AC adapter for your laptop. You can try to use a different AC adapter that has the same rating as your laptop's. The problem might be with the Charger.
4. But if all this does'nt work, consider getting a Computer Technician who can open up your computer and check the circuit board, there might be a problem with one of the chips
Mar 01, 2012 | ASUS Computers & Internet
GOOD DAY, the AC adapter model EXA0801XA DON`T CHARGE MY NOTEBOOK ASUS. ANY TIMES WHEN THE AC ADAPTER IS PLUG, TURN ON THE LIGHT BLUE, BUT AFTER 2 SECONDS (APROX) THE LIGHT OFF AND NEVER CHARGE MY...
Here are some steps you could take to try and solve the problem
  • Make sure all parts of the adapter are plugged tightly together.
  • Try plugging the adapter into a different wall socket.
  • Try the adapter with another computer to make sure that your laptop is not the actual problem.
If the adapter continues to fail after all previous steps are taken you may just need to buy a new adapter. Not to worry though as brand new adapters can be found for next to nothing on websites like Amazon.com or Ebay.com
Jun 12, 2011 | Aftermarket Group ADP-36EH AC Adapter...
Asus ac adapter will not wrk green light on adapter
First check the wall socket make sure you are getting power, plug a lamp into it for instance. If there is no green light on the adapter then it is bad and you will need to order a new one from your computer manufactor.
rate with 4 diamonds
Mar 02, 2009 | ASUS AC Adapter- Universal Notebook AC...
I have ASUS A3AC laptop bought in Australia. Now I am facing problem with AC power adopter I believe. Laptop only power up if i push it hard and try few times to connect and re-connect. Due to faulty...
All you need is a power plug adapter. At Radio Shack you can find one for US plugs to any other plug in another country. They will be able to order a reverse adapter, one to adapt Aussie plugs to US plugs. I'd start there and they'll find you one no doubt about it.
Regards,
Worldvet
Oct 21, 2008 | ASUS Computers & Internet
Computers & Internet Logo
887 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
