Question about Garden
Engine kicking back when i pull starting cerd
  • Garden Master
  • 14,406 Answers
Your chain may be too tight or chain lock is on.
Posted on Oct 30, 2012
Kawazaki kdx 125 wont start
KICK HARDER TRY PULL STARTING IT..IN SECOND GEAR..DOES IT HAVE ENOUGH COMPRESSION TO START?IT SHOULD START PULLING IT...START OFF WITH NO THROTTLE THAN IF NOT STARTING CRACK THE THROTTLE SO LIGHTLY AND SHE SHOULD FIRE OFF WHILE IN GEAR BEING PULLED OF COURSE BE CARE FUL NOT TO RUN INTO. WHO EVERS PULLING YOU..USE A LONG TOW ROPE..IF YOUR NOT A SEASONDED RIDER AND KNOW YOUR BIKE VERY WELL I WOULD NOT ATTEMPT THE PULL START...IF NOT CHECK YOUR COMPRESSION AND TIMING..MAJOR VACUUM LEAK MAYBE AT BASE GASKET..IS ENGINE SUCKING TO MUCH AIR? GOOD LUCK..
Mar 02, 2013 | kawasaki KDX 125 Motorcycles
2007 250 KLX Kawasaki is a pain to start most of the time. Dealer says its typical for this model
Find a new dealer. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a proper way to start the engine. Generally four controls are on your bike to assist in starting. Below are generic instructions.
  • The choke, used when the engine is cold. Pull the red knob for choke.
  • The " Hot Start " Lever, used when the engine is hot. Pull the lever to lean the fuel mix when the engine has been running.
  • The de-compression lever, always used.
  • The throttle, used to prime the cylinder, (power valve).
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm, (Power valve), in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. A flooded engine will often backfire. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), for six kicks. After six kicks go ahead and twist the throttle again for a second priming. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting. Note that not all carbs have a power valve. When a power valve is not present you should crack the throttle open only 1/8 inch from closed on each kick.
Jan 12, 2010 | 2007 kawasaki KLX 250
When trying to start bike there is a big backfire
There is a proper way to start the engine. Four controls are on your bike to assist in starting. Below are generic instructions.
Nov 17, 2009 | 1996 Honda Hornet 250
I cant start the bike
  • The throttle, used to prime the cylinder.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. A flooded engine will often backfire. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), for six kicks. After six kicks go ahead and twist the throttle again for a second priming. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Nov 14, 2009 | 2006 kawasaki KX 250 F
Difficult to start
There is a proper way to start an engine. Most bikes have four controls to assist in starting.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. A flooded engine will often backfire. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. Go ahead and give it another primer shot after the 5th kick attempt. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Could you take a moment and rate my answer? Thanks!
Sep 28, 2009 | 2003 Honda XR 250 R
2007 honda crf 250 r hard starting when cold ,
Sep 23, 2009 | 2005 Honda CRF 250 R
Bike is sometimes hard to start.When bike stalls and goes dead,it is hard to start again.This is a 2003 honda crf450.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. A flooded engine will often backfire. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Jun 28, 2009 | 2003 Honda CRF 450 R
Just bought a xr250 cant start not sure of technique,can an electric start be fitted
Electric start means a different engine. Yes, there is a proper way to start the engine. Four controls are on your bike to assist in starting.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. Now pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
A “very helpful” rating for this answer? Thanks!
Jun 17, 2009 | 1993 Honda XR 250 R
2005 ktm 525 sx is hard to kickstart , is there any trick to maket it more easy to kickstart?
  • The choke, used when the engine is cold. Pull the knob for choke.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Jun 07, 2009 | 2006 KTM 525 SX
2005 250 f 65 kicks to start
Several things can cause the problem. First, spring for a new spark plug. The stock plug is NGK CR8E. Now the plug is eliminated as a problem. Next, pull the slide out of the throat of the carb. Now remove the jet needle. Put the needle clip on the 4th notch, (this is the stock setting). Use only premium gas. Next, follow the starting instructions below.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. Release the de-compression lever and give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from a backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery and clean air filter will also aid in starting.
This will likely tame the beast for you. Please rate this answer. Thanks!
Jun 06, 2009 | 2003 Yamaha YZ 250 F
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
