Question about JVC Kw-r500 In-dash Car Stereo Cd Ipod Pandora Receiver W/ Front Usb & Aux Port
How do i install a jvc kw-r500 in my 96 corvette
I have a 96 corvette i want to install this radio in and i got a lot of wiring with the kit i bought i have to run to the factory amp.. not sure how to plug the factory harness to the new harness and then to the radio.
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
SOURCE: jvc kw-avx800 divx upgrade
go to ur settings. you will find a divx code. with that code you have to log on to the internet and sign up. with that code you enter it (following the instructions) then you will recieve the update, with that update it will ask you to save it to disc or removable storage device. once saved, plug it into ur jvx deck and it should update automatically.
Posted on Aug 31, 2008
etirbynnor
  • 655 Answers
SOURCE: Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Posted on Jun 06, 2009
sodeep
  • 3267 Answers
SOURCE: installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Posted on Jul 26, 2009
josetejas
  • 300 Answers
SOURCE: Just installed jvc kd-s16 and it loses power after
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Posted on Jan 19, 2010
I have a 1995 saturn sl1. And i took out my factory radio and Will be putting in a JVC KW-AV50 stereo. My question is, how the hell to i wire the jvc up?
Get an aftermarket harness and dash kit for your car. Harness plugs into existing factory harness. Color coded for radio.
Nov 11, 2017 | JVC Car Audio & Video
I need a owners manual ins. for kwx568 auto radio
Could the model be the JVC KW-XS68 CD/AM/FM receiver? Most JVC product manuals are available here: http://books.jvcservice.com/ . The direct link to the Instructions for the KW-XS68 is currently http://books.jvc.com/Download/1035753481/GET0755-001A.pdf . The installation guide is http://books.jvc.com/Download/1035753481/GET0755-002A.pdf .
I hope this helps. I can't find any radio model with the number KW-X568.
Aug 31, 2017 | Cars & Trucks
How to install jvc kw-xs68 radio in a Pontiac 2005
But the harness and kit from auto parts or from best buy then just match colors on radio and plug harness from old radio into new harness
Sep 21, 2014 | Car Audio & Video
I have a JVC KW-AV60BT, pandora loads & displays but no sound comes through
Just got this unit and had a similar issue, but mine was getting the iphone to play at all. On advice of the sales rep I bought the kit required to view movies with your iphone. The kit plug into the back of your radio using rca jacks and then utilizes the usb port. I can now use my iphone to play audio, movies and utilize i heart radio.
Jun 23, 2012 | JVC Kw-av60bt 6.1" Touchscreen In-dash...
I just bought a new kw-AVX740 radio and i have a 01 mustang and i don't really no how to install it
first and foremost you need to buy a car audio installation kit for your car model and year. Wal mart has some, but i think you may need to drive down to your local car audio shop and buy one from them if wal mart don't have them. Remove the old/factory radio. If an aftermarket radio is already installed then you may get lucky and find the harness already installed, but depending on what kind or radio it is( ex: DIN or Double DIN), but the specs for your radio is Double DIN(fat) so you may still need to buy the installation kit. Once you have the kit, everything is color coded, just match the wires and connect, then plug the harness after you have secured the wires. For a clean professional installation look, solder your wires(60/40 solder and soldering iron needed) and seal the connection with a heat shrink tube(audio shop carries the tube as well) and your good to go. I found you the install manual, just copy and paste(make sure all wires are connected with keys off the ignition until everything is good and connected)
http://resources.jvc.com/Resources/00/01/50/LVT2173-002A.pdf
Jul 14, 2011 | JVC Car Audio & Video
Radio wont power up
check the line fuse on the red and yellow wires if there are any should be housed in clip plastic container.
Jan 07, 2010 | JVC KW-AVX810 Car DVD Player
KW-AVX710 Screen stays black (off) untill I hit the open button
So I decided to verify all the connections after I got frustrated with it. Everything was correct except one wire that was on the new harness I got that for my car that was labeled "12V fused" (supposedly the key on power source). I tested it with my volt meter and it did not have power at any time, even with the key on. The constant power source wire was hooked up so that's why I was able to open the face and eject CD's and DVD's but not do anything else (like when your ignition is off). So I ran a new wire from my fuse panel and everything works now. Just like my Thermodynamcis professor says "nullius in verba" (take no one's word for it), just because the wire was labeled doesn't mean it's right! Hope this helps.....
May 25, 2009 | JVC KW-AVX710 Car Video Player
1998 CHEV CORVETTE...I'M INSTALLING JVC KW-AVX800 IN DASH VIDEO DVD CD PLAYER AND 2 AMPS . ONE AMP IS A 2400 MONO D BLOCK BLITZ FOR THE SUBS ...AND A 1200 WATT FOSGATE AMP FOR THE HIGHES AND THE MIDS
For a JVC KW-AVX800 wiring would be:
Black - chassis ground/negative
Yellow - always on B+ (12V + terminal of battery)
Red - Accessory B+ (goes to 12V when ign key is switched to Acc)
Blue - Power/motor of antenna
Blue/White - remote trigger on of external devices such as an amplifier
Orange/White - park light
Brown - mobile phone sensor
Light Green - parking brake
White & White/Black - left front
Gray & Gray/Black - right front
Green & Green/Black - left rear
Purple & Purple/Black - right rear
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Nov 03, 2007 | Car Audio & Video
JVC KW-AVX706 front face problems
for ppl still having this problem.. more than likely the dash kit is to small and not allowing the radio to close properly. soulution: get one that fits, or get a dremel and shave down the plastic on the dash kit that prevents the radio from closing... hope this helps some1
Oct 05, 2007 | JVC KW-AVX706 Car DVD Player
JVC Kw-r500 In-dash Car Stereo Cd Ipod Pandora Receiver W/ Front Usb & Aux Port Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
