Question about Jandy AQUALINK RS TELELINK KIT
I have a Jandy RS6 combo model 8157. My pool light will turn on & off on it's own. The spa heat enable qwill come on on its own.
    Top Expert:
  • Jandy Master
  • 7,915 Answers
Disconnect 4 button spa control if it goes away replace spa remote
Posted on Jun 07, 2015
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandu Aqualink Pool/Spa Controller RS6
AQUALINK GUIDE BOOK
SOURCE: Why am I getting a 6700 REV C message on my AquaLink RS6 home spa
I had the same issue, but only after I pressed the reset button on the side of the panel. After a couple of days of troubleshooting, I found a small nick in the wiring from the outdoor unit to the indoor paneI. I turned off the breakers to the pool equipment, rerouted a new cat5 cable, but cat3 will work just as well, wired it up and all was good. A local pool guy wanted to charge me about $2000 to replace both units. I spent less than $5.
Good luck
Posted on May 28, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
  • 31 Answers
SOURCE: I have a jandy rs6
I assume you tried just resetting the controler with the tiny button on the side of the controller itself?
Posted on Mar 31, 2011
Why is the Jandy RS6 Intellitouch Controller Extra Aux / Solar power plug always ON/Powered?
Your logic seems workable...
(I got nothing ... should work).
Trouble shooting says to check & clear "phantom"
programming... (Pg. 30: sounds like hokum 2 me).
My best advice..
Go to page 40 and contact their customer support.
Jandy AquaLink RS Installation Manual Warranty
1-707-776-8200
Carnac the Magnificent
Jun 22, 2014 | Jandy AquaLink RS All Button, Wired, RS6...
I have Jandy/Zodiac LRZE legacy heater and Jandy RS6 controller. When hooked up to RS6 and there is a call for pool heat the heater ignites but shuts off in about 30 seconds. When I disable the TSAT...
check your dip switches on the inside panel of the aqualink if you still cannot get it to work i would use the pool to 1 wire of a new wire you will run to the heater then 2nd wire to com then on the on the PCB board going to pins 1 and 2 of the big plug then turn heater all the way up when heater button is pushed or activated it will turn heater on and off
Aug 05, 2013 | Jandy Legacy LRZ Heater
My RS6 all button is blinking, but pump still comes on as scheduled and can use buttons for other functions except heater wont fire. Outside unit display says Err. Diagnostic codes say 8157 Rev L and...
This issuesounds tricky. I recommend you call the Jandy technical support at 800-822-7933and they should be able to help you figure this issue out. Ihope this helps.
Sep 18, 2011 | Jandy Aqualink Rs4 One Touch Control...
I am replastering my spa and want to put a new LED light in. Can I control the different light functions with th Aqualink and the button on the spa deck?
I have a Aqualink RS one touch control system, model 8157 RS6 Combo. The backlight in the control panal is out, the panal works fine, but does not light up, so it is hard to read. How can I replace the light? Do I have to replace the whole panal unit? Is there a bulb to replace? thanks, David
Feb 23, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Freeze protection interrupts spa operation in cold weather
the filter pump is used for other features during spa use disable the freeze protection but turn back on after using spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
279 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
