Question about Keys 4500T Treadmill Walking Deck
Ive got a keys fitness 4500t and ive got a E44 code what can i do to fix it. thank you
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Apr 05, 2016 | Electrolux Washing Machines
How to do with E40 code of Electrolux EWF 1074?
programme):
E41 - Door open
Possible causes:
Dado
Aug 24, 2015 | Electrolux Washing Machines
What does e44 means
you will have to google the make/model error e44 to find that out as we have no info from you
Mar 10, 2015 | Washing Machines
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Mar 03, 2015 | Bosch Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
programme):
E41 - Door open
Possible causes:
Dado
Feb 24, 2015 | Electrolux Washing Machines
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
programme):
E41 - Door open
E44 - Door interlock sensing circuit faulty
Possible causes:
Dado
Aug 02, 2014 | AEG Washing Machines
Fix e44 error
drain pump or hose filter clogged
Nov 03, 2013 | Bosch Washing Machines
E44 = ?
Good Morning bennysia28 - Typically, error code E44 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
May 08, 2013 | Electrolux Washing Machines
1992 cadillac Deville OBD code read out and what it means.
E13-Oxygen sensor voltage stays between 0.307 and 0.609 volts for 64 seconds. Engine was at normal operating temperature at a speed over 800 RPM.
E44-Right oxygen sensor was lean for more than 50 seconds when engine was warm and at 800 RPM or greater.
E52-PCM has lost primary battery power.
E58-Pass Key fuel enable was not correct.
F47-PCM has received bad data from IPC for 3 seconds while engine speed was 500 RPM or more for 3 seconds.
F48-EGR open command was given during off idle operation. EGR opening should cause the mixture to be slightly richer because of the low oxygen content of exhaust gas. Vehicle speed was over 35 MPH and engine was warm.
Good luck and hope this helps, keep me posted be glad to answer any questions you may have.
Jul 05, 2009 | 1992 Cadillac Seville
Keys 4500T Treadmill Walking Deck Logo
56 people viewed this question
Top Keys Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Keys Exercise and Fitnes Expert? Answer questions, earn points and help others
