Question about Galaxy Radios DX-959 40-Channels Base CB Radio
GALAXY 959 CAN TRANSMIT BUT NO RECEIVE
I HAVE A GALAXY 959 IT WAS WORKING THEN IT SOUNDED LIKE THE PEOPLE THAT WERE TALKING AT THE TIME WERE CUTTING OUT, THEN IT JUST STOPPED RECEIVING ALL TOGETHER. CAN ANYONE HELP? THANKS
Try the external speaker /if that is not working you may need put in a new receiving chip it is on the right side has 10 pins.
Posted on Jan 05, 2009
Need wiring help for Galaxy 959 Cb Mic
1) shield / ground 2) yellow/ audio 3) red / transmit 4) white / receive
Mar 17, 2013 | Galaxy Radios 959 40 Channel Am/ssb Radio
Tip
Galaxy DX 959 CB radio no transmit or talkback
Hi, I have a problem with this CB radio. The PA works good but after installing the MOSFET kit as mentioned here http://cgi.ebay.com/DUAL-POWER-TRANSISTOR-MOD-KIT-GALAXY-949-959_W0QQitemZ190256621565QQcmdZViewItem?hash=item190256621565&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 it wont transmit and I cant hear myself on talkback nor do I hear the roger beep. The PA amp works though.
on Oct 15, 2008 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx959 will not receive. Speaker is working. S meter is showing incoming signal.
the over power doides may be blown. you should start there .they should be marked D-1 and D-2. you may want to replace them with diodes of a higher rating.
Jun 26, 2012 | Galaxy Radios DX 959 SSB CB Radio
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Is it best to use in am mode in normal trasmitions on a cb radio dx 959 galaxy?
  • This Galaxy was built as a CB to run on AM (11 Meter). The majority of people on the CB run AM stations. Sideband (upper and lower) is where the carrier is removed and the wave being transmitted on is cut in half. You can do this just fine but mainly if you want to talk to someone and you both know your going to be on Sideband for a little privacy. 38 LSB is a great channel to catch some DX side band on world wide. But yea, AM is the best to find people to chat with.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Apr 24, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
375 people viewed this question
Top Galaxy Radios Radio Communications Experts
Mike Charette
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
