Question about Goodman Manufacturing DSZC160481A/GMVC951155DX/CAPF4961D6 4 Ton 16 Seer 95% Efficient 115,000 BTU Variable Speed Goodman Gas Furnace / Electric R410a Hybrid Heat System
Why does furnace heat cut back?
Heater barely gets up to temperature
    Novelist:
  • 187 Answers
You might try checking your return filter. The new filters (pleated 3 month, ie real expensive ones) cut back your air flow 35% from the amount the regular 30 throw away allow. When air flow reduces the temperatur from furnace increases and can cause inadvertant high temperature limits to trip. If you are using a clean return filter, next you need to physically observe the air inlet side of your cooling coil to see if it is blocking air flow due to being dirty. If you have trouble with seeing the inlet, you might need to get a professional to take the air handler apart.
Posted on Apr 15, 2014
The flame stops burning when the blower kicks on but the furnace is still calling for heat
If this is a standard house heating system, could the blower control switch be set too high and too close to the high temperature setting. If the temperature reached the high limit, the flame would be cut off.
Gary
Feb 10, 2011 | Coleman Heating & Cooling
Heater turns on and heats garage to set temperature, than shuts off. when the temperature drops, the unit kicks on again. everything starts working again but only for a few seconds and than shuts off. it...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor.If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 11, 2010 | Mr. Heater Natural Gas Garage Heater -...
Where do I set thermostat when temp is 10 degrees outside?
Setting a thermostat has nothing to do with outdoor temperature, but more to do with what is a comfortable setting for you and your utility bill.
A common misconception associated with thermostats is that a furnace works harder than normal to warm the space back to a comfortable temperature after the thermostat has been set back, resulting in little or no savings. This misconception has been dispelled by years of research and numerous studies. The fuel required to reheat a building to a comfortable temperature is roughly equal to the fuel saved as the building drops to the lower temperature. You save fuel between the time that the temperature stabilizes at the lower level and the next time heat is needed. So, the longer your house remains at the lower temperature, the more energy you save.
Another misconception is that the higher you raise a thermostat, the more heat the furnace will put out, or that the house will warm up faster if the thermostat is raised higher. Furnaces put out the same amount of heat no matter how high the thermostat is set; the variable is how long it must stay on to reach the set temperature.
In the winter, significant savings can be obtained by manually or automatically reducing your thermostat's temperature setting for as little as four hours per day. These savings can be attributed to a building's heat loss in the winter, which depends greatly on the difference between the inside and outside temperatures. For example, if you set the temperature back on your thermostat for an entire night, your energy savings will be substantial. By turning your thermostat back 10 to 15 degrees for 8 hours, you can save about 5 to 15 percent a year on your heating bill -- a savings of as much as 1 percent for each degree if the setback period is eight hours long.
Hope this helps..........
Nov 23, 2010 | Goodman GMS90703BXA Heater
When i turn my furnace on with auto along with heat the fan will not come on so i have to turn it on fan and then it still will not come on so then i take and turn the switch off for about five minutes...
Hi, sounds like the problem would be more likely in your furnace than with your thermostat. I would suspect a defective fan switch, these switches are temperature activated and turn on the blower at a lower speed than the Fan "on" would.
Jan 11, 2010 | Honeywell Electronic Programmable...
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
I have a 25,000 BTU hanging furnace, will this heat a 900sq foot garage that has been insulated.
Here in Vermont we design heating systems to perform at -10 to -20 degrees. Depending upon how tight the doors and windows are, it may if your temperatures don't drop below 20 degrees. It may take a while to heat up and I would not expect any temperature over 62 degrees inside the garage. Maybe a 50,000 Btu heater? Remember the output may be 20% less than the rated input of the heater.
Dec 29, 2009 | Dayton Gas Furnace Heater
Goodman Manufacturing DSZC160481A/GMVC951155DX/CAPF4961D6 4 Ton 16 Seer 95% Efficient 115,000 BTU Variable Speed Goodman Gas Furnace / Electric R410a Hybrid Heat System Logo
57 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
snowmanii
ray gallant
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
