Question about Hammering
Robin rgx 5500 generator will not stay running
I have a robin rgx 5500 generator and it starts up and run for 30 seconds and cut off. what can i do to fix it
  • 154 Answers
SOURCE: I have a Generac MC 5500 portable generator. It
when power tools get old they draw more amperage. 6.8 amps new might be 8 amps. over loading when older.
Posted on Jun 14, 2009
  • 297 Answers
SOURCE: Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Posted on Jul 15, 2009
SOURCE: The MOTOR on my Wen Power Pro model 5500 runs
The brushes need to be filed smooth or replaced. 15 minute job, remove 2 bolts on the generator cover ( side opposite the pull start ). Remove 2 more bolts holding a black plastic thing about 4 inches long on the left. Behing that piece, there is 1 bolt holding in the brushes ( red and white wire attached ). Remove the brushes and if they're not smooth, file down and reconnect everything. I was done in 15 minutes in the middle of Maine woods thanks to my Leatherman.
Posted on May 15, 2010
#1 Taper
  • 1041 Answers
SOURCE: Robin RGX 5500 Generator owners
Here it is:
lawnandgarden.manualsonline.com/manuals/mfg/robin_america/rgx4800.html
Good Luck!
Jim
Posted on Sep 26, 2010
  • 436 Answers
SOURCE: runs good but no generatoring would like service
Easy enough.. here is link:
http://servicenet.deltaportercable.com/Products/Detail?isId=true&productNumber=BSV550-W&selectedType=14778#
Good luck with it and let us know if you nned more specific help
Thanks
Posted on May 01, 2011
Capabilities of the Robin 2400is generator
no
ac units are 2000 watts minimum, washing machines are 1500 watts minimum, microwave is what is on the plate and start at 650 watts but most are 2000 watts
the 2400 is the peak out put for start up of fridge , washer etc and the running wattage will be 2000 watts or less ( duty cycle )
to run more than one of the nominated items at once you will be needing a 5500 to-6500 watts unit
they handle a start up surge of 6500 watts ( larger one) and will comfortably handle 5500 watts run full load
it works like this , the plate on the gen set is the surge short time load capacity of the genset and not the duty load which is 500 to 750 watts less than that plate wattage
for example your 2400 is is surge rated at 2400 watts but duty load is less than the 2000 watts
many people make the mistake of buying a gen set that looks big enough but do not calculate the maximum load capable on being put on the gen set
fully loaded uses more fuel /hr
wears out faster
has power surges as the extra load cuts in and the motor struggles to get back to required rpms for voltage and cycles
will not cover extras like lights ,
a much large gen set will take it all in it's stride , no power surges, better economy, less stress
talk with an electrician , do your maths on everything you wish to run and that which you forgot about then add 1000 watts to the duty cycle and that will be close to the gen set you require
Oct 17, 2016 | Electrical Supplies
Why does troybilt generator engine keeps shutting off when throttle is moved from choke to run position?
Give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 05, 2014 | Briggs Stratton Portable Generator 305cc...
Why does my briggs and stratton 310000 run rough on startup?
look for fuel puddling in the carb area (strong fuel odor on start up or after primering) may need a needle and seat valve
Jul 11, 2014 | GE 7KW Generator System With 50A, 10...
Generator won't start
model# 1971 starts on first pull runs about 3 minutes and cuts off
Jun 30, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
I have a Onan Microquiet 4000 in my Motorhome. It sat for a while and then I was unable to start it. I took off the carb and thoroughly cleaned it. The generator fired right up after that, it runs great...
Sounds like the float is out of adjustment, it's not keeping the bowl filled.If the float is not at correct height or the bowl was not placed back in the correct position it could show these symptoms , some bowls have a small indent on them and that recess should clear the float for proper movement of float. Or check to make sure that you have no water in fuel tank. Good Luck...
Mar 31, 2011 | Watts Onan Portable Generator - 4000 ,...
Robin RGX 5500 Generator owners manual
www.jackssmallengines.com/.../Robin%20equipment/MANUALS/GS0597B.PDF
www.jackssmallengines.com/.../Robin%20equipment/MANUALS/PUB_GS0597B.PDF -
There you go one owners manual.
Sep 26, 2010 | Garden
Hammering Logo
97 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
