Question about Refrigerators
My ge refregerator stop cooling and freezing the light comes on but nothing else works is it the main control board
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is your model number?
Posted on Oct 30, 2012
SOURCE: GE Fridge intermittent
I had the exact problem with my GSL25JFRFBS. It turned out to be a bad control board. The service technician that replaced the board said that the lights dimming on the on the ice/water dispenser is a direct indication of the control board being bad. This cost me $303.53 and my refridgerator is only a little over 2 years old. You can buy a new control board - WR55X10656 from GE online for a little over $157.00. From what I've found, this is an inherit issue with this model.
Posted on Nov 09, 2008
Just_Bobz
  • 448 Answers
SOURCE: GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Posted on Jan 10, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Posted on Mar 25, 2009
  • 41 Answers
SOURCE: GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Posted on Apr 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE side by side refrigerator and freezer not working
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug until we solve the problem the internal overload inside the compressor will be damaged. I am ready to help you on this just let me know, Sea Breeze
Posted on May 20, 2009
Hi. Our GE GSH25JSDD SS side by side drive just stopped freezing, cooling. The fan is on inside freezer and lights, and motor down on bottom, back is running. Drain is clear. Won't cool down.
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | GE Refrigerators
My fridge and freezer stopped working. Nothing's running. It doesn't cool or freeze. None of the mechanical parts are working. Only the lightbulb turns on. What can be wrong?
if removing the mother board made no difference to the fridge operation then it would be logical that the mother board is faulty
These machines do not like power surges( can originate many miles away)
have a technician check it out
May 06, 2015 | GE Refrigerators
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
My GE PFS22MISBWW stopped cooling suddenly. Lights & power work; sound of light fan but no cooling. Please advise
That main control is known for causing this issue, replace the board it will fix the issue friend
Apr 22, 2011 | GE Main Domestic Board WR55x10656
GE side by side refrigrator stop working
If there is nothing operating but the lights you are going to need the board linked below which is for your model.
Main board
May 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerater stops cooling/freezing and restarts?
maybe stuck in defrost cycle. usually controlled by a hv board on rear of refrigerator
Jun 21, 2009 | GE Refrigerators
CAnnot set REfregerator teperature going to 65 all the time
you have a bad main control board -- $300 plus to fix it. the board is on the back of the unit. if you can get the part locally, it usually comes with instructions -- good luck.
Dec 13, 2007 | GE PSS26SHRSS Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
