Question about Kenmore Series 70 80 90 PN281798 Dryer Motor
20 yr old 70 ser.replaced start switch,still does not engage-next step?
Replaced start switch-comes on when pushed-will not stay on. Next possibility?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Oct 31, 2012
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: kenmore 80 series washer, replaced lid switch
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Posted on Aug 14, 2009
  • 255 Answers
SOURCE: 17 yr old kenmore 70 series HD washing machine
The transmissions never go out on these. The problem almost always lies elsewhere. If you have someone handy around, it would pay to have them at least look at it and test the wig-wag solenoids. (They switch the gearbox functions/waterpump control.) Cheap fix. Good luck.
Posted on Jan 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 'large capacity' dryer won't start
It appears your controller board/timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
TheMobilian
  • 8220 Answers
SOURCE: Kenmore washer 70 series(top loading) only
The water temperature selection switch would be what I would check next.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 30, 2011
Starter will spin but will not engage on z445
The bendix may not be pushing the gears to engage the flywheel. Take out the starter and have it tested.
Jan 19, 2014 | Bruder Cat Skid Steer Loader
Replaced alternater andbattery ignition light stays on after 30 sec in running
if battery was over 3 yr old -the alternator often fails next from rechargin so much--hav it tested at a parts place pronto
Jan 10, 2011 | 2010 Ford Transit Connect
My Dyson DC 14 is about 5 years old now and when I push the on/off switch it starts, but it won't stay on unless I hold down the on/off switch.
Sounds like you would have to get the on/off switch replaced. You could try one thing prior to trying to replace the switch or taking it in for repair. After 5 years of use there may be some dirt that got into the switch. Unplug the unit and spray some Contact Cleaner (available at Radio Shack) or some WD 40 into the switch area. Use a bit of it so it can work its way into the switch. Then, here comes the good part, turn the switch on and off for a few minutes. The action will somewhat clean the contacts of the switch IF the cleaner was able to get into the switch. If you try this and it does not work, the next step I would take would be to disassemble the unit and get at the switch to see if wires have come of and if they have not, check the continuity of the switch and last ditch fix, replace the switch. Paul
Oct 10, 2010 | Dyson Vacuums
Rinse spray stays on after cycle. Control box displays "rinse", it appears to finish, but water still comes out of the top spray head.
Removed the solenoid assy, loosened the valve assy a little and re-tightened. The valve now works. Next step is to dis-assemble the valve and try to clean it out.
Looking for a replacement part, but the AM14 model is old and parts are hard to find. The specs say its a 20-30 V coil and the AM15 appears to use a 115V part.
Possibly the o-ring inside the valve can be replaced. I did notice that blackish water came out of the valve assy when I looosened it.......
Oct 01, 2009 | Hobart 42 in. AM14C-154 Free-standing...
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Dryer will not start.
Check your door switch. It sounds like the door switch is not engaging (closing properly). If the switch contacts stay open, the interior light stays on the dryer will beep when you attempt to start it. This is the push button toggle switch on the door frame. This is a common symptom of this problem.
Open the door and push in on the switch, If the switch is working properly, the light will go out. If it doesn't, you will need to make sure the switch is not loose. Next, check the wires leading to the switch to make sure they are not loose, broken or grounded to the case anywhere. If all the wiring checks good, you will need to replace the switch. This is a very simple repair. Let me know if you require further assistance. I hope this helps you.
Oct 16, 2008 | Whirlpool Dryers
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Kenmore Series 70 80 90 PN281798 Dryer Motor Logo
70 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
