Question about HP Photosmart C5180 All-In-One InkJet Printer
I am having problems finding the color that needs replacing.
I took replaced one at a time. No good. I replaced all of them. No good
Please help
    Genius:
  • 1,239 Answers
HI
***At the printer***
• Check the ink cartridges. If any cartridges have run out of ink, replace them.
• Check the connection of the head flat cables on the main PCB. (If either of those cables is broken or damaged, replace it.)
• Replace the main PCB.
• Clean the head caps and wiper of the maintenance unit with a Rubycel stick.
• Replace the maintenance unit.
• Check that the drain tubes are not bent.
Posted on Jan 04, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 04, 2009
    They have/had some together with drivers for them. The
    BJC7100 has large ink tanks and can take standard colour as well as
    photocolour inks (and black of course). You can use card as there is a
    straight-line path option (manual feed).
    Delete the current driver for the printer and reinstall the driver or go to the correct website for your printer and find the latest and greatest driver for your particular model and download it, sounds like something is corrupt... Hope this helps...
  • HP Master
  • 19,396 Answers
If you are using original cartridge this may be just a faulty printhead, in that case replace the printhead.
Tell more about the problem,
Posted on Jan 03, 2009
  • HP Master
  • 13,433 Answers
If even after replacing all the cartridges the printer still complains that a cartridge needs to be replaced try cleaning the contacts on the printer and on the cartridges. Also try unpluging the printer for a moment and try again, reconnect all the cartridges.
your printer may require service.
Have montgomery ward chest freezer 15.8 cu. ft. model #85058 and need enter door panel. It is cracked around edge.
Sorry to read about your problem, I hope this helps you out.
you cannot find replacement parts for you unit, unless they are used. you can get a replacement compressor or probes.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Freezers
My Sony tv screen blinks off and on and timer/standby blinks 5
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
Feb 26, 2010 | Sony KP-53HS10 TV
Color cartridge does not work - color faded. Just replaced AGAIN today - same problem
Remove it,replace it couple of times.
Run a nozzle and printhead cleaner check,
from your printer's properties, maintainance.
align too, just to be sure your setup correctly.
Check your printer settings for quality of the print.
there are various choices there for you.
Should be good then
Regards
Richard.
Apr 21, 2009 | Lexmark Color JetPrinter Z52 InkJet
Magnavox 50" DLP Tv power light comes on but then i hear a buzzing noise and then two red lights come on the tv. at no point does the picture turn on during this time. Can you please give me a possible...
Your bulb is burned out. I have had the same problem. It seems this television has an overheating problem--and short bulb life. I have had our 50 Magnavox dlp for two years and just put in the second bulb before Christmas. You can buy the bulb from a dealer on ebay for $99 and install it yourself. I is not in the housing so you have to carefully take out 4 screws and replace the bulb without touching the face of the bulb. To buy the one from Magnavox with the housing is much more expensive. I think the first time my husband replaced the bulb it took about 45 minutes--this time it took about 20.
Dec 16, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I'm noticing all my pictures have a pink hue to it, and pink bar on top
Hello,,,
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck....
Jul 14, 2008 | Canon PowerShot A80 Digital Camera
Please help
Antoniette, I had the same problem, however, I heard a noise like the shattering of glass. After replacing the lamp without resolution, I took the guts out only to find that the color wheel shattered. I ordered a new one myself for $90 and will attempt to replace it, it definitely beats the $450 service fee that I was going to be charged. At worse, I'll return the lamp and color wheel and contribute that $450 to a new 56" DLP with a 5-year warranty. You can find well documented instructions online, I used http://kploymp.net/dlp_cw.aspx.
Apr 09, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
Hd50lpw164 noises
You are right it is the color wheel that is causing all that noise. The color wheel has to replaced, oil or WD will not fix it. To get a replacement it is best to call the manufacture and they will ship the part directly to you.
Feb 23, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
No power with remote or manual power switch
Your convergence module is probably bad. It is a plug in module, so labor would be lower if the convergence settings are still good. The bill would be about $300.00 If not, the labor for convergence would add to the bill. If the whole job needed full convergence the cost would be about $500 to $600. Hope this helps, Lee http://www.CrazyComputers.com
Jun 22, 2007 | RCA P60921 60" Rear Projection Television
HP Photosmart C5180 All-In-One InkJet Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
