Fuction shortcuts model ONA11HOO87
I lost the Nano receiver for my wireless mouse and keyboard,Model:ONA11HOO87. Where may I order a replacement?
You cannot. The usb transceiver is a matched set with the keyboard and mouse. When you loose it, you have to replace the whole set.
Feb 05, 2018 | The Computers & Internet
My touch pad not working properly
Call Toshiba and talk to experts from the actual company. This should help. :)
Technical Support: 1-800-457-7777
Jan 11, 2008 | Computers & Internet
How do I clear the timer fuction on my GE profile microwave
hi Donna.
this is all i could find out.
How to clear timer on GE microwave? Clearing the Timer on the Microwave. On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function. Review the Owner's Manual for model specific directions.
Clearing the Timer on the Microwave - Products - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?contentId=16868 Search for: How to clear timer on GE microwave?
or this.On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How to clear the timer fuction on my GE profile microwave Google Search
Nov 26, 2017 | GE Microwave Ovens
Tv on stand by not fuctioning
Have a shop look at it so they will know what the brand and model number are, no magic wands here.
Dec 12, 2012 | Televison & Video
I HAVE SINGER TV MODEL:SCT21M63STC.WIDE OFF FUCTION IS NOT WORKING FROM REMOTE,IF THERE IS WIDE OFF FUCTION REMOVEL IN REMOTE THEN PLEASE TELL ME.
if the problem appears to be only in your remote control for wide off button, and other button function seems not affected... i suggest that u clean the remote control inside, of course you need to disassemble it and clean the rubber pad. esp. the wide off button. it happens when the carbon contact was cover w/ dirt...last sol. is to buy a new "same" remote...
Feb 11, 2011 | Televison & Video
Tell me all the key fuctions of the key board
Keyboard keys vary from one model to another but the basic keys are all included. I have a link to help you on the functions of each key and some shortcut keystrokes for your convenience.
Sep 23, 2010 | Logitech Cordless Mouse
How to completely dismantle a Hobart N50 or KitchenAid Model G
If you only want to service the unit and not open the case, you can add grease through the gear shifter plate opening once you remove it. if you have a grease gun with a flex nozzle that's a bonus.
If not it is a messy job. Keep lots of paper towels at hand and use a narrow spatula to get the grease inside. Get as much in as you possibly can.
To remove planetary, with pin removed, spray a bit of wd-40 or other penetrating oil into where the pin came out of let it penetrate for a few minutes. Plan-A Take two screwdrivers and gently try to pry the planetary away from the body of the mixer. Plan-B Add a bit more lubricant to the shaft pin area and install a beater, then try prying with one screwdriver while putting downward pressure on the beater, alternate prying on both sides of planetary. Excessive force at the planetary top can/will crack it as it is a molded piece of metal. If you found this solution helpfull, please rate it. Good luck.
ricardok45
Nov 19, 2008 | Hobart N50 Stand Mixer
Phone automatically switch off when i select go to option
in my experience almost 7250i and 6610i had a the same problem if you select GO TO automatically turn off.. the problem of that is Softwarre(program) you need to reprogram your phone..
Sep 28, 2008 | Nokia 7250i
Compaq keyboard
You probably need to load the Compaq utility that assigns and activates the keys. Go to http://h18000.www1.hp.com/cpq_support.html
enter the model number of your compaq computer, and search the available downloads for the utility.
Nov 27, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
