Question about Whirlpool Washing Machines
How to lube or grease a brake and drive tube after removal
I removed the brake and drive tube during repairs and noticed some oil comming out from the housing. I cleaned everything dry and i'm ready to replace the tube but dont know if I should grease the entire housing or the rubber seals prior installation and what about oil
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
PUT IT ON THE TUBE BEFORE YOU REINSTALL IT
Posted on Nov 02, 2012
2 Suggested Answers
oldTech2332
  • 2341 Answers
SOURCE: Good morning, I'm about to
no place to add and grease/oil
THE IMPORTANT THING THOSE IS TO OPEN THE VENT HOLE ON NEW TRANSMISSION AS STATED ON THE NEW PART BE SURE TO POKE A HOLE ON THERE
The grease you see now should be cleaned or it may permanetly stain your clothing...it was from oil leakage from the old trans/gearcase
Posted on Aug 26, 2011
Where is a diagram for grease /lube under chassis locations
under-body only.check
my guess not gear lube. right>? axles/gear boxes, (a plenty)
2wd, or 4wd?
what do you want to grease, you never said.
bearings, tie-rods, ujoints etc. only>?
are you asking for ZERKS? only?
or all places on car with grease.?
or
are you saying just grease? and only things that must not be removed for service with grease, (like wheel bearings and splines)
The free book posted over 200 times.
chapter 0, read that? lube/maintenance?
see the 4wd exceptions?
my 2010 has none.
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
the map includes LUBE points.
but adds gear boxes,axle gears, GL4 and GL5 (gear lube) is lube. too
but engine oil is not lube, to 1996 books.
1993.(oldest for GC) the word LUBE is wide reaching...
i love the NUT typo.
my guess is you meant grease only
and with no disassemlbly
Mar 16, 2016 | 1996 Jeep Grand Cherokee
How to chassis lube a 2010 chevy malibu
You are not taking a boot off the grease fitting. The little rubber boot you're removing is the dust boot for the bleeder valve on the brake caliper. The 2010 Chevy Malibu,as with most cars, have non-serviceable suspension parts.
Feb 23, 2015 | Cars & Trucks
Good morning, I'm about to install a new gearcase into my Whirlpool direct drive washer. After removing the old gearcase I noticed some grease inside the drive tube top rubber seal. I don't know if...
Aug 26, 2011 | Washing Machines
I need a new motor for the Gemmy Ferris wheel, Item 71-92125. The motor is a Huayi 60TYZ-A
Did you get an answer to your question about the Ferris wheel?
May 24, 2011 | Toys
Back passenger wheel locking up
Hello chrisz28: My name is Roger and I will help with your question. Most problems that cause a wheel to lock up are associated with brake problems. Look at the wheel in question. Do you see any grease or liquid on it or the backing plate. If it is wet or looks damp you will need to remove the tire and wheel in order to remove the brake drum. After the drum is removed look at the brakes are they coated in liquid or in heavy oily grease. Liquid would be brake fluid, heavy oil would be axle grease. Axle gear lube would also be slimy and caked on everything. The axle grease would be a bad bearing and axle seal and most likely a bad axle. Should you need further help please just ask. Please rate the answer. Thank You for using and trusting Fix Ya. Roger
Dec 18, 2010 | 1992 GMC Sierra
How do I drain the gear oil from a Bosch Brute Jack Hammer
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Squeeling sound while driving and especially when brakes are applied even though my brakes are new on my 2002 Sunfire . They assure me it is not a mechanical concern but it is annoying. Weather seems to...
check to see if the tabs on the pads arent bent, try sandong the pas with emery cloth to remove the glaze and reinstalling them with a sound coating between the pad and caliper, available at a parts store, either as a spray or tube, and lube the caliper slides with silocon grease
May 09, 2010 | 2002 Pontiac Sunfire
Right front brake engages but doesnt disengage. master cylinder is basically new put it on then parked it for two years now this is happening.
Have you removed, checked,cleaned & lubed calipers? FYI , After sitting for 2 years, all brakes should be inspected, clean & lubed, as well as conditions of fluid lines.
Apr 11, 2009 | 1991 Chevrolet S-10 Blazer
Front fork oil
Take em off and do it right ... chances are high that your other tube seal is about to go as well, so do both of them at the same time. Even if you can't do it on your own (There may be a special tool involved that you don't have) you can still take the separated tubes to the shop, and you'll be charged alot less since you did the removal work yourself!
Nov 10, 2008 | 1986 Yamaha FZ 750 AE (U.S.)
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Washing Machines Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
