Question about eMachines Computers & Internet
Why is my wireless conneted with limited access
Trying to connet to the internet but got connected with limited access got excellent signal but can't connect please help
  • 3 more comments
  • max carson
    max carson Oct 29, 2012
    Limited or LOCAL? can you access the internet? Wired or wireless? What OS are you using?
  • julie_evans3
    julie_evans3 Oct 30, 2012
    limited no can,t access the internet im on sky broadband and os is windows vista
  • max carson
    max carson Oct 30, 2012
    If you haven't repaired it yet you might try to unplug everything, remove batterys from EVERYTHING, replace batterys, Plug everything back in allow the broadband modem, the access point to do there self tests, start your laptop that should re-set EVERYTHING, If that faile re-set your access point at the re-set button at the rear os the device. Hold the button in for a few seconds and release, that will re-set to default settings. You will need to set-up your access point with a new password ang settings.
  • max carson
    Also try this procedurehttp://www.cs.cmu.edu/~help/networking/I...
  • max carson
    let me know if you repair it.
  • 14,384 Answers
Ok,here's the solution,I have my lap top about 100 feet away from my router,have a man cave,I have it plugged in always and when the wind is blowing,my signal will get lost and I get the same reading as you do,but it picks right back up,it's the signal,my vizio,smart tv is connected by wifi and I loose my signal there too,Here's a video to watch,enjoy.http://www.youtube.com/watch?v=Lf1UgEJq8NY
Posted on Oct 30, 2012
  • max carson
    I have a Smatr TV, HP printer, Two laptops, Ipad, Two desktops connected to my network a Comcast Cable Moden and a Linksys WRT 54G and I do not get a weak signal.
  • Thomas Perkins
    Thomas Perkins Oct 30, 2012
    try turning power off at the Linksys or pushing in the reset button on back.
  • 218 Answers
SOURCE: laptop wireless won't connect to internet signal is excellant
I believe your problem is described in this article by HP. Read it and then call the HP number listed. If they agree that it's one of the problems in the article, then they will replace the motherboard free.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Posted on Feb 12, 2009
  • 56 Answers
SOURCE: my laptop cannot connect to internet
check your ip address and default gateway are correct
Posted on Mar 20, 2008
SOURCE: Acer laptop not conneted to 2Wire147 Moderm
what is the password to get into the wireless network?
Posted on Jun 30, 2008
vincent721
  • 240 Answers
SOURCE: Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Posted on Apr 03, 2009
Geekman
  • 32281 Answers
SOURCE: I HAVE A SHARP PC-GP10-CM MODEL THAT I WANT TO
First you need to sign up with an Internet Service Provider than can provide a broadband connection wirh DSL (ADSL in Australia) or a cable connection together with a wireless router with a built-in DSL or cable modem. Alternately a wireless router plus a separate DSL or cable modem.
The modem needs to be configured in accordance with the ISP's instructions.
Then the Wireless router and the wireless card in the computer needs to be configured. Follow these steps:-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
If you are not sure, then get a computer savy friend to help you.
Posted on Oct 22, 2009
How do i connet and access the internent with my wi fi
If you use a wireless router with a DSL or Cable Internet service then your laptop with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans.
Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD. http://www.fixya.com/support/r6165994-setting_up_broadband_connection
Mar 04, 2013 | Computers & Internet
Hi there the belkin54g is in my brothers room he has the ps3 and his pc running of it and iam connecting to it with my laptop wireless connetion but it keeps coming up limited internet access were my...
check your IP address, subnet mask, and gateway settings on your laptop. Also you can try setting your network settings to dhcp and reboot your laptop.
Apr 03, 2011 | Computers & Internet
Internet connetion setup problem
I also faced the same problem in past. You can first of all disconnect your LAN or Wireless connection as sometime is it not recognizing the network properly. You can enable it again and restart your laptop. Try to access internet once your laptop is on as I have resolved similar problem in this manner.
May 28, 2010 | ASUS Eee PC 900HD Netbook
I've had my lap top for about a year now. It used to make me connect to places that allow free wifi. Now, it says "conneted with limited access" even with a full bar signal! What should I do to resolve...
Dont warry not a problem with your laptop. Just find out the service. i am sure right now that wifi system is limited access mode. thats why u get full signal but can't use the internet. Visit to your operator and config your LAPTOP IP with there server. It will start working again then. Thx.
Jan 30, 2010 | Sony VAIO Notebook
Accr 4730z wireless problem
the wireless router  might not bee conected to the internet
May 13, 2009 | Acer Aspire 5610-4648 Notebook
Card is green, wireless router is green , but no internet
r u c'in any message as limited r no connectivity in wireless connection,did u chk if u r able to go online wth the cable connection in ur laptop
Nov 05, 2008 | Dynex 802.11g Wireless-G Laptop Card
Error
you're using a custom firmware i guess....3.52? or higher.
its just a normal message. the firmware is actually programmed to show that message if there is no available wifi signal or weak signals or if you're trying to connect to a restricted connection.hope this calmed you down.dont worry its normal for that firmware. :)
Jan 30, 2008 | Sony PlayStation Portable (PSP) Console
Connecting ps3 to internet
Your wireless router probably has a wep or wpa passcode that you will need to enter into your PS3.
Oct 15, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
146 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
