Question about LaCie Computers & Internet
HDD Rest I've forgotten my password ... how can I reset the drive (no need to recover any data)?
  • LaCie Master
  • 27,725 Answers
The LaCie Ethernet Disk Mini is an external hard drive that you can connect to your computer through an Ethernet connection.
Those who work on large projects that might require more memory than a computer has can use one of these devices to save information from the project.
Video editors often use hard drives such as these because videos often take up so much memory on their computers.
To keep information on the drives secure, change the administrator password from time to time.
Type "http://edmini" into your Web browser.
Logon to the page using your current login information. The default username and password is "Admin."
Click the "Users" tab.
Click "Change the Administrator Password."
Type and confirm the new password.
or if this fails
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Posted on Oct 30, 2012
night71
  • 328 Answers
SOURCE: dead hdd
I am assuming that you have a Windows platform. Take the hard drive out out and try it on a Mac. Sometimes a Mac will pick up faster than Windows. I would try that first for sure. Finding a Mac computer is not hard if you have a computer retail store near bye. Some smaller outfits may test it for you for free and hook it up to a Mac. If my solution sounds off the wall: consider opening your hard drive knowing that any wrong tinkering can easily result in a totally useless drive. If you are ready to open it if a Mac doesn't work, go slow and don't bang it around. You can't get very far, but you could check for any loose wires and check the board with a tester when no power is attached. You should not try to open the area with the physical drives, any wrong move there will destroy any chance of recovery. If all seems to fail, then yes, give it a tap or so. The FBI will do it for a crazy cost that would make buying a car easy.Good luck
Posted on Nov 11, 2007
tonybudz
  • 162 Answers
SOURCE: How can recover data from free agent desktop hdd
Well you should have gone in and marked the sectors that you think are bad, by formatting it odds are you wiped the data off it, you can try a low level recover but I dont think your going to find much. Sorry format means format.
Posted on Aug 12, 2008
  • 53 Answers
SOURCE: Hi, My Seagate 80GB IDE HDD is not detected in
If data in your hard drive is really important to you, try to look for a similar model hard drive. Then swap the logic board of the good hard drive with the defective hard drive. If the cause of problem is the logic board, then your hard drive should work by now. If you are not that technical, you can ask a technician to do this for you. You can buy a second hand hard disk for a few bucks at ebay.
Posted on Dec 29, 2010
  • 241 Answers
SOURCE: cant initialize drive to recover
Don't be so worried about ur data. There are some gud data recovery software available on internet. But first of all please stop using d drive anymore to increase d chances of recovering files. Then you need rely on professional data recovery tool. Download the software from the following sites http://www.recoverdeletedfile.org and follow the steps
1. Install the software on your system.
2. Install ur hard disk as external drive to that system.
3. select the drive(usually G or H for External drive) , click Start. Now the scanning process will start to search the deleted files. After a while you will then get a list of recoverable files.
4. Press Recover to perform full recovery.
Posted on May 20, 2011
bronk50
  • 27725 Answers
SOURCE: I've a 16 gb pen
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers if you need any more help just post a reply
hope this helps
Posted on Jul 23, 2011
I need administrator password for DELL INSPIRON 1545 WITH tag 4Q8J2N1
Forgot windows password? Try to use Windows Password Reset or Windows 7 Password Reset to create a password reset disk, and use the password reset to reset your windows password.
Rest or recover your forgotten password for windows 2000/2003/2008/xp/vista/win7 in few steps:
Step 1: Download and install Spower Windows Password Reset.
Step 2: Create a CD/DVD or USB password reset boot disk with SWPR.
Step 3: Boot your computer from password reset boot disk.
Step 4: Recover the forgotten password for administrator account.
For more information, please visit Windows Password Reset:
Aug 30, 2011 | Computers & Internet
I cannot use my DELL Laptop because I forgot my password.
Hi, once you forgot your password and for no reason to recall it. Just press cntrl-alt-del keys simultaneously and log in using username=administrator and password is none. The default username of your computer if not altered is administrator. Once you successfully logged in you can edit your forgotten password in users properties.
Jun 21, 2011 | Dell Vostro 1500 Notebook
Forgot my password?
If you have forgotten your PayPal password, you will need to follow these steps to create a new one:
  1. Visit the PayPal website at www.paypal.com
  2. Click 'Problem with login' under the 'Log In' button.
  3. Choose 'I've forgotten my password' and enter the email address registered to the account.
  4. Enter the security code by typing the letters and numbers shown then click 'Continue'.
  5. Confirm account ownership by selecting and entering the information you want to verify and click 'Continue'.
  6. Create a new password, which must be at least eight characters long and should not contain any spaces
If you are unable to recover your password, please contact PayPal Customer Service.
Please rate me if my soultion was helpful, thankyou.
May 10, 2011 | PayPal Accounts
I forgot the password. so i cant log in now. wat i should do?. help me
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password, but you forgot administrator password, that way doesn't work. you must use software to recover administrator password. This method is very easy. You can go to this site http://www.reset-windows-password.com/how-to-reset-windows-password.html
Jan 05, 2011 | ASUS Eee 4G Notebook
How do i get passed my hdd user password i forgot the password
A couple of days ago, I lost my windows vista admin password. I solved the problem with the help of Windows Password Seeker. Not just support XP/Vista/2000/NT, but also compatible with windows 7, I tested it on my computer installed with Windows 7 and remove the local user and admin accounts password successfully. It's worth trying. You can download it from: http://www.passwordseeker.com/howtouse.html
May 19, 2010 | Toshiba Satellite A205-S4617 Notebook
Forgot login password
You can get a Password Reset disc download and burn to CD. Copy/paste the address below, into your address bar of your browser.
http://pogostick.net/~pnh/ntpasswd/cd080802.zip
Download this file and burn it to CD. Put into drive and turn on PC, and boot from the CD. Follow instructions, choose the correct USER. & BLANK the password. make sure you say OK to write the data, and reboot. The logon password will now be reset blank.
The above is for Windows. If however your is Linux, then the below applies to you. Go to that link,below, and follow instructions to reset password. http://aplawrence.com/Linux/lostlinuxpassword.html
Apr 11, 2010 | ASUS Eee 4G Notebook
Cannot open the laptop, forgot the hardisc password
Download the software called unlock HDD and follow the instruction.
Here is the download link
http://rapidshare.com/files/275453518/Unlock_free_HDD_space.rar
Note:This software will easily unlock or remove the password but at the cost of all the DATA inside.
Jan 02, 2010 | Acer Computers & Internet
Dell inspiron password removal hdd
Usually, the hdd password is set the same as bios password. So we can recover the BIOS password directly from the laptop security chip. But if the hdd password is set not the same as bios password, how do you remove hdd password for Dell inspiron?
Therefore, you have to use password cracker only. If you still remember hard disk password, or you remember bios password and bios password is the same as hard drive password, follows the below article to remove it.
http://isunshare.blogspot.com/2013/11/how-to-remove-hdd-password-on-acer-laptop.html
May 06, 2009 | Dell Inspiron 700M Notebook
FORGOT PASSWORD
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} In addition to reinstall your system, the easiest way to solve the
problem is to use some Windows Password Reset program. The
program will enable you to reset the password to "Blank" with no
-reformatting or installation. Do all the job for you automatically. It's worth a try.
http://www.resetwindowspassword.com
Jan 03, 2009 | Acer TravelMate TM2480-2705 Notebook
Computers & Internet Logo
455 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
