Question about Panasonic Viera TH-42PZ80U Plasma TV
Panasonic viera plasma TV will not display tuning option in set-up mode. Please can you suggest how I can fix ths.
I recently changed the box the ariel lead fits into as my toddler broke the last one. I can't tune the TV is as set-up mode does not display tuning option for digital TV, though it does for analogue, Any ideas how I fix this, please.
    Sergeant:
  • 349 Answers
If you click on the TV button on your remote control. I believe that this puts the TV back into Digital mode.
You can also go to the Main set up menu to get into the various tuning options by pressing the MENU button on your remote. There are some devious little settings hidden away in there.
My TV was not showing that it had HDMI when I selected AV inputs...I eventually found that it was able to be restored through the MENU access.
Posted on Oct 29, 2012
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Posted on Oct 31, 2007
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
jerryg50
  • 1667 Answers
SOURCE: panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
Posted on Apr 14, 2008
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
  • 8457 Answers
SOURCE: Panasonic plasma viera tv will not auto tune, can
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Posted on Mar 13, 2010
Can't get it out of SAP mode. tried two different remotes. TV doesn't respond.
1. If you're watching TV via a Cable or Satellite box , then the SAP (Secondary Audio Programming) is activated in the box, not the TV. Check with your TV service provider how to activate/deactivate SAP in their box.
2. Only if you're using the TV's own built-in tuner to watch TV (you're changing channels by using the Panasonic remote for CH up/down), then press the SAP button on the Panasonic TV remote to cycle through the SAP options.
Mar 15, 2016 | Panasonic Viera TH-50PX80U Plasma TV
How do I get my Panasonic plasma tv out of power save mode?
Maybe you can go to the "Settings" and change it that way, possibly to "Cinema" if that is an option. Hope this helps you.
Feb 11, 2015 | Panasonic TC-P50UT50 viera tcp50ut50...
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
Tv keeps going into standby mode
There are many reason for a Plasma display to go into standby mode. It is difficult to describe all here by this window. If you wish to get more details, check this link. It has details about the faults that can occur to a plasma display. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 30, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Mar 13, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
R-tune button doesn't work. defaults to video mode after turn off
the mounting screws into the tv may be too long and short out a communication cable. remove all mounting hardware and see if it still has this problem.
Dec 02, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-42PZ80U Plasma TV Logo
406 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
