Question about Panasonic Cameras
Can't take picture with panasonic lumix and green dot flashes
SOURCE: Panasonic lumix DMC-FZ50
I have an DMC-FZ7K. I had the exact same problem, here's how I solved it:
Turn on the camera. Set the mode dial to "P".
Now press the button labeled "MENU SET".
In the menu that comes up, scroll up and down until you find a menu item named "PICT.ADJ." When it is selected, press the right arrow button.
In the sub-menu for "PICT.ADJ", select the "SATURATION" item and change it to "standard" or "low". Press "MENU SET" to save the changes.
You should now see a difference in the next pictures you take.
Posted on Jul 09, 2008
  • 12 Answers
SOURCE: How do I delete a picture on the Panasonic LUMIX DMC-LC40
When reviewing the images on the LCD with the image you want to delete showing on the screen you push the button that has a trash can icon. The camera will ask you if you want to delete the file yes/no; scroll to yes and use the right arrow button to confirm.
Posted on Nov 28, 2008
  • 65 Answers
SOURCE: how to take high res pictures with the panasonic Lumix 07
Press [MENU/SET] to display the [REC] mode menu & select the item to select. 7M will give you the highest resolution. Hope this helps you.
Please Rank!. Tx
Posted on Aug 07, 2009
  • 11967 Answers
SOURCE: Panasonic lumix DMC-ZS1 - won't record video
It might be telling you that the card you have in the camera isn't fast enough to keep up with the demands of a video recording. You need to buy a more expensive card with a faster speed rating.
Posted on Jan 19, 2010
  • 20 Answers
SOURCE: Panasonic Lumix G1. Viewfinder does
You probably changed dioptre adjustment in your camera. There should be a adjustment ring next to the eyepiece.
Posted on May 08, 2011
Testimonial: "Fantastic. Thanks."
The flash on my Panasonic DMC-FZ100 doesn't work, I've tried 'forced flash' and thats not working either?
Hello Ray, This is not something a user wants to attempt !!! The camera really needs to be repaired by a tech. You will do more harm than good by trying to fix it yourself and will cost even more if you damage something.
Best Regards, Russell
Jan 22, 2013 | Panasonic Lumix DMC-FZ100 Digital Camera
Problem with color on my lumix dmc-fh25 camera
Set the camera's white balance to match the lighting. Most indoor lighting has a yellowish cast to it, while by default cameras are set for sunlight.
Jan 10, 2013 | Panasonic Cameras
Is there a way to correct color issues on my lumix dmc-fh25
Jan 10, 2013 | Panasonic Lumix DMC-FH25 Digital Camera...
Panasonic lumix dc vario can't download pictures onto computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Apr 02, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
RED DOT
If the dot is not visible in print, but only on the camera's screen, the its only the LCD that is faulty.
If the dot is visible on screens and in print, then yes, it could be the sensor. Try taking pictures without the digital zoom. Chances are the dot is only visible with the digital zoom because the picture is interpolated.
If all else fails, you can try cloning out the spot in an image editor on the computer.
Dec 01, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Cameras Logo
145 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
