Question about Olympus Stylus 720 SW Digital Camera
When I turn the camera on it only stays on for about 5 seconds and then automatically turns off. Re-charging the battery does not help. Is this the sign of a defective battery? Current batteyr is 2 years old.
  • Anonymous Feb 26, 2009
    I have the same problem. It happened after my daughter took it on an overnight hiking trip at Mount Rainier, and I think it must of gotten too cold?
    Problem Solver:
  • 6 Answers
Unless it's turning off while you're still taking photos, I believe this is similar to many electronic devices (i.e. laptops), which turn off after a certain period of inactivity so that the battery won't die when you accidentally leave it on when putting it away etc.
Posted on Feb 28, 2009
  • Batmanfan Feb 28, 2009
    Oops! Sorry! I misread "5 seconds" as "5 minutes". Sounds more like a battery problem, or a problem with your battery charger. I had a similar problem, and discovered that my charger wasn't working properly. I take it with me on a lot of trips, and I must've damaged the wires in the cord.
My Nikon D3100 will not turn on. Is there something wrong with the batteries/memory card? Or rather the camera body itself?
It could be either the battery or the camera.
If you have a second battery, try it. If it works with the second battery then the first battery is bad.
If you don't have a second battery, take your camera and battery to a good photo store. They should have a second battery to try. You might be able to test your battery with one of theirs. This will tell you whether the battery or the camera is bad.
Oct 04, 2016 | Nikon D3100 Digital Camera
My camera does not turn on with the battery in it. When it does turn on it stays on for less than a minute. I have already replaced the battery twice.
Welcome to FixYa.
Two reasons why the camera automatically switch off.
1. The battery is exhausted
- try to insert fully charged battery or replaced a new fully charged battery.
2. The camera stopped due to malfunction.
- removed/ re-insert battery and switch the camera on.
For more details and troubleshooting steps of your camera, here is the link for your free manual. Just click here
I hope this solution will help.
Feel free to send us your comments and suggestions if this solution is helpful.
Thank you for using FixYa.
Apr 07, 2011 | Cameras
Wont stay on
I could not find the vpce890 digital camera referenced on
But, I did find that the battery should be charged by placing in the charger until the light turns green.
Are they Li-ion batteries or other type?
Jul 16, 2010 | Sanyo VPCE890 Digital Camera
The battery wont charge and it is only the second
Try turning the battery over in the charger. It sounds like the wrong side is up.
Jun 03, 2010 | Nikon COOLPIX S570 Digital Camera
My camera wont turn on and lens stays out
are you using the battery that came from the box KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001
first charged the battery for 4hrs and make sure when you charge it theres a light indicator in the camera., you may also try to turn On the camera while its charging in a AC adaptor., If its did the same thing call kodak toll free 1 800 235 6325. it means the camera gear lens is already defective thats why your camera will not stay On
Oct 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera on for 5 seconds red flashing light then turns off
that definitely sounds like a battery problem.
when you charged the battery, did the light stay red, and then turn green when it was finished?
if it flashed red, try this:
MATERIALS: 9 volt battery, 2 pieces of wire the same length, casio battery
DIRECTIONS: connect the + sides of each battery with a wire, and the - sides of each battery with another wire. [I just held them there, but maybe you can tape them if you're having trouble.] Hold it for 30 seconds. Then try charging it. If it doesn't work keep trying it until it does. TRUST ME! It took me 5 times to do it effectively.
If your battery has gone too long without charging, sometimes it won't charge correctly any more. So do this.. IDK why it works, but it did for me!
Nov 19, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Samsung L200, you turn on and after 5 seconds you hear 3 beeps and its turned off automatically
Hi Bruno,
first, try to reset the camera to factory defauts. Your memory card maybe corrupted as well, try to format it on the other camera. Another issue is when lens get stuck. Check if the lens go in and out of the camera smoothly. Good luck!
Olá Bruno, como você parece ser brasileiro como eu, vamos em português também. Tenta resetar a câmera e formatar o cartão de memória. Vê se as lentes não estão emperradas e se elas entram e saem da câmera de forma bem suave. Boa sorte!
Oct 04, 2008 | Samsung L200 Digital Camera
I think that both your batteries are bad. Because the batteries have sat on a shelf not being used the batteries will only take a surface charge and not fully charge. Bum a battery from someone with a Sony that uses the same battery and see if that works.
Sep 20, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Can i turn it off?
It should turn off after 60 seconds of inactivity however the type or memory in the camera is called volatile memory and it requires a charge to store data. So even if the display is blank if you have pictures on the camera it will be pulling a charge from the battery. The best thing to do would be to download the pictures from the camera as soon as you can so that the pictures stored in the memory aren't pulling a charge from the battery.
Mar 19, 2008 | Disney Pix Micro Digital Camera
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
Feb 25, 2008 | HP Photosmart M527 Digital Camera
Olympus Stylus 720 SW Digital Camera Logo
80 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
