Question about Element ELCHW402 40 in. LCD HDTV
Pc audio to element tv - Element ELCHW402 40 in. LCD HDTV
    Top Expert:
  • Element Master
  • 14,553 Answers
The set has to have a input for sound that is compatable with the PC.
Posted on Oct 30, 2012
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
My element electronics tv says no signal
Two things to try:
1. Connect a DVD or something else to one of the rear audio/video inputs to see if set works that way.
2. Check to make sure set in menu is set to tuner and cable---if the tuner in the set is bad a cable box with audio/video outs on the back can be hooked to one of the rear audio/video inputs and will bypass the tv tuner--you will stay that input to watch TV and change channels with the box----
The cost of renting a box is minor compared to having to replace the tuner in the set.
Mar 24, 2012 | Element Electronics Televison & Video
My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
Jan 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
What would cause the sound on a lcd hdtv 32 inch flat screen tv to just stop?
What other device are you connecting to your tv and how are you connecting it?
If you connect via a single HDMI cable that may be causing your audio problem. Some Tv and STB have handshacking issues which can knock out audio and/or video. The only solution would be to replace the HDMI cable or switch to composite cables.
Dec 14, 2009 | Element Electronics FLX3220F 32 in. LCD TV
I just bought a Element 32LEOQ and the sounds goes off after 15 minutes
Try hooking up the powered PC speakers to the Audio line output RCA jacks, if the sound does not cut out, then the problem is in the power amp sections that drive the speakers, it may be over heating and shut itself off, most Class D amplifier are used in the flat screen TV will shutdown if it is over heating or short circuits.
Nov 01, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Can't find audio out on my 32" element to hook up my dvd surround sound system. i have a cable box and my dvd system hooked up to the tv. the surround sound works great from my dvd but there doesn't seem...
If there is it would be the "rca" cable that has a red and a white marking, and it would say "out" on it or "audio out" Some TV do not have an audio output so you maybe right.
Aug 12, 2009 | Element ELC-HS321 32 in. LCD TV
Hooking up head set
I went over the Manual for your TV, Sadly, it doesn't have a port for headset. It only has one audio output port for the stereo system call Digital audio out. The port on the back of the TV has a one for the size of a headset jack. But, it's only for the PC audio in port.
I wish there was some other way to hook up the headset for your son. But, the only option I see is to take the TV back and get one that has the headset port.
Sorry I couldn't help you out more. :(
May 28, 2009 | Element Electronics FLX-2610 26 in. LCD...
Hot to connect acer aspire mini laptop to digital lcd tv?
Press the Blue function key and toggle the screens. You can view, the Laptop, the Laptop and Screen, or just the screen.
Also you will need to flick through the channel button on the TV to get to the PC interface. Since you indicated you were using a VGA cable, this is likely the missing element.
Note: The VGA cable does not carry audio, you either had a separate audio interface to the TV or you were using RBG/Composite/S-Video/HDMI. So check to make sure you are using the correct cables.
Jan 07, 2009 | Acer Aspire 5100 Notebook
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Jul 11, 2008 | Televison & Video
Element ELCHW402 40 in. LCD HDTV Logo
223 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
