Looking for a manual for a American Standard hydronic gas heating system
Want a owners manual for our American Standard hydronic gas heating furnace. The house was built in 1968 and the furnace is the original furnace. The previous owners left us no manuals. Thanks, Vickie
Noggin
  • 944 Answers
SOURCE: Urgently need user manual
These 3 links are for (in order): Daily programming (same time every day), 5day/2day programming, and weekly (different times each day) programming; http://www.kirklees.gov.uk/knh/publications/rwb9daily.pdf http://www.kirklees.gov.uk/knh/publications/rwb9daily%20wend%20day.pdf http://www.kirklees.gov.uk/knh/publications/rwb9daily%207day.pdf Hope this helps :)
Posted on Apr 25, 2007
SOURCE: Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Posted on Jun 22, 2008
machtcl1
  • 61 Answers
SOURCE: how to light a American Standard furnace
If it is an old furnace with a manual pilot light there are pilot lighting instructions usually on a door or panel. If it is 15 years old or newer it probably has either a spark ignition or a hot surface ignitor. These can't be lit manually. If they fail they usually require parts to be repaired.
Posted on Jan 02, 2009
vanni7
  • 163 Answers
SOURCE: 3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
SOURCE: Looking for an Owners Manual
Hi, not sure if this will help. Click the link and choose your model. All in PDF format and can be downloaded for free.... http://www.manualz.info/Manuals_pdf/SUZUKI/
Posted on Jan 15, 2009
Wiring diagram for 1960 american standard oil furnace model no.CS-195-60
Wow, you are going to have a heck of a time finding that. Try contacting American Standard. They may be able to help you.
Dec 04, 2017 | American Standard Heating & Cooling
Stage 2 is on the screen but no heat will come on. American standard thermostat. A/c comes right on but when heat is turned on "stage2" comes up on the screen but the heat won't Not a touch screen.
You should look at your furnace and see if any safety lights are flashing. Make sure your thermostat is set to heat.Check system your using for updates.
Nov 19, 2016 | American Standard Heating & Cooling
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
I have a American Standard furnace Freedom 80 Mod# AUD080C936H3 and am looking for a manal or can you tell me how the exauhst is done. Can I use PVC
Hello, The only time pvc is allowed is if the Furnace is 90% or greater in effiecency, the combustion gases are cooler due to the fact that two heat exvhangers are used. One pipe will be you air intake and the other the exhaust and they can be routed through the roof or sidewall. If the Furnace is 80% then you must use double wall vent pipe and have it connected to either a liner in a chimney or routed through a roof but pvc can not be used.
Aug 28, 2011 | American Standard Heating & Cooling
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
American Standard Gas furnace acting weird
I am concerned of the readings you have given. 120 volts to ground, but 168 volts to neutral? And having 10 amps of current at the "ventor", but only 1 amp for the whole furnace worries me, because power for the "ventor" comes through the furnace.
You should not have 168 volts to anything! Unless somehow 240 volts is feeding the system, and there is a medium resistance short somewhere.
The controller boards are sensitive to AC polarity (if you will). Neutral should be tied to neutral on the board. You can check that by testing for voltage between the neutral terminal and chassis ground (assuming the chassis is properly grounded.). The hot leg of incoming power, which should be 120 volts, should be connected to the terminal that says 120 VAC.
If your getting 168 volts AC somehow, then something is wrong, and you need to disconnect power from this unit until you find the cause.
As a heat-A/C tech, you should know the sequence of operation for all furnaces is pretty much the same. The boards, while manufactured by different manufacturers, all operate pretty much the same way.
Let me know your findings in reply and I will attempt to help you more.
Jan 20, 2009 | Heating & Cooling
Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Jan 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
254 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
