Question about Emerson InSinkErator C1300 Chrome Commercial Hot Only Single Handle Basin Tap from
I have an insinkerator hot water dispenser with stainless steel tank, and the tank is now leaking. I'm wondering if it can be fixed or needs to be replaced
  • Emerson Master
  • 5,245 Answers
Replace water heater if tank wall is leaking.
These things have short warranty period.
Stainless steel will theoretically last longer, but steel tank water heaters have replaceable anode rod to prevent rust-out.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Be sure to recycle the old metal.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Posted on Oct 30, 2012
  • 4 Answers
SOURCE: Insinkerator instant hot water tank leaking
When you cut the pipe it has to be cut square or it will leak . Try recutting the end of the pipe and then reinserting it. If this doesn't work then the only thing you can do is replace the fitting.
Posted on Dec 16, 2008
  • 92 Answers
SOURCE: Can you clean the tank on an Emerson Hot 1 model hot water dispen
if it was me i would try to get vinegar into it let it sit for a while and flush it out
Posted on Feb 05, 2009
  • 659 Answers
SOURCE: insinkerator hot water heater takes a long time to dispense water
It may have mineral deposit buildup on the inside. You will need to consult your maintenance manual to see how to flush the unit and clear it of deposits. You can also contact Insinkerator for the information as well. You can use vinegar to clean it just like you would a coffee pot. Take the inlet supply off and using a funnel pour the vinegar in and turn the unit on.
Posted on Apr 03, 2009
gary1121
  • 332 Answers
SOURCE: How to replace heating element for InSinkErator W154 water heater
take the front cover off, it is just snaped on, there you will see it, depending on the age of the unit insinkerator will replace it for free, you just have to install it, but for the most part it might be cheaper to change the unit
Posted on May 30, 2009
SOURCE: Hi, my insinkerator hot water
I had the same exact problem. I looked up my purchase information and the unit is under warranty for 3 years (mine was 1 month out of warranty). I called Insinkerator 1 800 558-5700 and they were very willing to ship me a new unit for free. I found them to be very helpful, and willing to work with me. I just got off the phone with them and I can expect my replacement unit in 7-10 days (no charge). So I will install/replace my leaking unit. Good luck!
Posted on Nov 05, 2010
Insinkerator instant hot water faucet
Insinkerator stainless tank does not have anode rod to protect from rusting. So these water heaters rust out at welds. And must be replaced. And this is frequent problem.
Copy following link for installing under-counter water heater and see manuals for various models available. Non-insinkerator water heaters have anode rod to protect from rusting:
Gene
Jul 23, 2013 | Water Heaters
In sink erator instant hot tank leaking at the bottom of the tank
Must replace tank.
Insinkerator stainless steel tank does not have anode rod to protect against depleted tank wall.
Copy following link for tips installing under counter heater, and manuals for several different brands
Add comment as needed and fixya will not send me email to reply with more detail
Jul 15, 2013 | Water Heaters
Tank
Insinkerator has stainless steel tank but does not have anode rod to protect against depleted tank wall.
Leaking tank means broken weld, and you must replace tank.
Add comment as needed and fixya will send me email to reply with more detail as needed
Jul 15, 2013 | Emerson InSinkErator W-152 Point-Of-Use...
Insinkerator hot tap faq
Check all the connections, take the cover off after you shut down the power. If the connectors are not leaking, replace it
May 04, 2013 | In-Sink-Erator InSinkErator HC-WAVESN-SS...
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
How do I find the water leak in Emerson insinkerator H770-SS
The use-and-care manual says that the 'product will eventually fail,' and to install a drain catch pan.
The product has stainless steel tank with 3 year warranty. 1-800-558-5700.
The manual does not show parts diagram, element, or anode rod. This indicates that operation is inside a sealed 1-piece unit not meant for repairs.
High clorine content of water, and hard water, and water pressure over 80 psi will adversely affect any tank heater, and shorten lifespan causing probable leak.
Turn off power:
If you can remove cover from H770, then inspect 750 watt element for possible leaking. Then replace with new element of unknown type if element is leaking.
If leaking is coming from the tank itself, then the unit cannot be repaired. This is true for all tank water heaters.
http://waterheatertimer.org/Leaking-water-heater.html
Aug 04, 2012 | Emerson Water Heaters
HOW TO REPAIR A LEAKY INSINKERATOR HOT WATER DISPENSER...... Found the following at another website when looking for a solution to my leaky hot water dispenser. Worked great for me, so wanted to share the...
What if you back the temp down to say 165 or so would that not keep the plastic from frying?
Also does that model not sit ambient until hot water is needed and is not "hot" 24/7/365 as you
stated? Just wondering.
Feb 06, 2011 | Emerson Water Heaters
Feb 05, 2009 | Emerson InSinkErator C1300 Chrome...
InSinkErator Instant Hot Water Faucet leaking from heater unit model #GN1100
Make sure that there is no leaks traveling down the hoses or at the connections on the top. The tanks can leak, if you have the Stainless Steel tank the following information applies - Stainless Steel Tank: 3 years, with an extended service plan available when installed by an InSinkErator Pro Circle™ plumber. I you product is under warranty I believe that you can call the number that is printed on the tank and literature.
Dec 04, 2008 | Mountain Plumbing Mountain The "Little...
Emerson InSinkErator C1300 Chrome Commercial Hot Only Single Handle Basin Tap from Logo
712 people viewed this question
Top Emerson Water Heaters Experts
Donni Steen
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
