Question about Hyundai W240D
W241D Hyundai starts flickering when LCD processor runs hot. Already changed the caps on the PSU and the video Board. Some people say it dont heat up so fast with reduced backlight. Please help !
5 Suggested Answers
  • 7 Answers
SOURCE: my engine runs hot if I don't turn on the heat/defrost
thermostat is stickung,needs to be changed
Posted on May 26, 2009
  • 14585 Answers
SOURCE: help please my 2001 hyundai elantra at start up it
It's the drive or main belt that you can see on the front of the engine. Probsbly one of the pullies locking up or the belt tensioner is going bad.
Posted on Nov 18, 2010
SOURCE: I have a 2000 Hyundai
Timing Chain not set correctly
Exhaust Converter Blocked
You can NOT run any motor without
a thermostat
The Temp Sensor won't work
correctly and you will have closed
loop issues. Thus run on long term
fuel trim. Run rich and run hot and
ruin converter
Posted on Feb 26, 2011
SOURCE: 2004 hyundai sonata over heating no leaks
probably have an air pocket in the cooling system.
Posted on Apr 25, 2015
Hannstar ACER j mv-4 doesn't start up
no pc stated, maker or model #,, sounds kinda DESKTOP>?????
no oS stated
step one is test the MV4 on a known working pc,!!!
why wait, this so basic....
are you using VGA to VGA or DVI to DVI connections??????
the DESKTOP,
no sound means the fans are dead and PSU dead.
The PSU will run for 1 second and fans run now. if not PSU is dead.
if fans do run and stop that means PSU dead or mobo shorts or bad reg on MOBO. or bad ram. strip it down to test that.
ok fan runs that means 12vdc good. if stay running,
and if PSU stays up, then NEXT TEST IS Screen
is it 100 % dead, or do you get text or logos."
100% dead means to me bad VGA card(or chip GPU)
if the Hot key for BIOS fails, that means bad POWER/
or bad VIDEO card.
the fans run but are silent, I envy you.. sell me your fans....
im 1/2 deaf from Vietnam and can still hear all my fans.
my DT has 4 fans min. (it's Alien-ware box++++)
CPU, GPU and PSU, and 1 case fan,all must work.
do yours?
when you power on a PSU, the fans run and stay running
if that takes sides off so be it, ever clean the 5lbs of lent seen inside from 5 years, collected?
If you dont service any pc, this packs up and the CPU overheats
and shuts its self down by DESIGN.
why no do that service first.
see that CPU, see those fins, see that pack up there.
blow it out, outdoors, using CAN-0-AIR
mine over heats my GPU fast with lent, my Graphics car runs super hot and fast and lent is NOT ALLOWED here. ever..
old pcs with slow cpu ,, tend to packup slower, well lets say
they can run longer with huge lent here. its just slug processor so...
that is what it does.
recap.
  1. fans all run.
  2. BIOS dead?
  3. screen dead. no words no text at all.
  4. MV4 tested on other PC works. proves PC bad.
  5. LENT PACK job. as all do every year here, all.
  6. Bad VGA caRD. or using wrong port if PC has 2 VGA jacks. !
Jun 22, 2017 | Compaq Computers & Internet
Mag LT916S Blank screen after start up
How do you know that your LCD is the real root cause of this issue? I suggest you try to use a KNOWN GOOD MOnitor/LCD to confirm it first.
Sep 18, 2007 | Mag Innovision 19" LCD Flat-Panel Monitor...
Sir, I have a Dell optiplex GX110. At the motherboard there is a long brown slot in which a board of 4 expansion slots has been pluged. The first problem was that I had removed the heat sink from the...
When you inserted a test probe into the slot and you saw a spark, then you have short circuit a component on the motherboard and have done a major damage to the motherboard.
You need a new motherboard, most desktop cases have standard mounting holes, you may be able to purchase a motherboard from other manufacturer to fit in the Dell.
Oct 09, 2010 | Dell Optiplex GX110 (2909T) Motherboard
My Monitor is flickering. I changed the monitor twice (CRT & LCD). But the problem does not solve. I read few forum, they said it is a common problem of magnatic field by TV, Refrigaretor, etc. But now...
if you can borrow a compatible video card to some of your friend replace it if your monitor still flicker then change the psu of your pc, hope this help
Sep 18, 2009 | Computers & Internet
I have a gateway w340ua lapetop the screen dont turn on
Does the laptop appear to bootup?
Does the hard disk appear to be spinning and the hard disk LED light flashing?
If so the laptop maybe booting up and the LCD screen maybe faulty. If so follow these instructions to determine the screen fault :-
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 06, 2009 | Gateway Computers & Internet
Changed thermostat,flushed radiator,fan comes on but it takes a long time,car temp guage goes all the way up to H(hot) until i turn heater on full blast then goes back to normal temp????
have you try to change oil? some times engine heat does' not just come from malfunctioning of the cooling system . But sometimes its the oil that runs to the engine . if the engine oil is dirty already it could also cause the engine to over heat. do to change the engine oil of your Acura Legend.
Jul 28, 2009 | 1994 Hyundai Excel
My engine runs hot if I don't turn on the heat/defrost
May 26, 2009 | 2001 Hyundai Santa Fe
Power and fan run light flicker in front does not boot up
Relace the psu it's a dodgy Bestec ..replace it with a winpower psu 400 watt , they are cheap but they work better.
Mar 28, 2009 | E-Machines T1842 PC Desktop
Two tone Siren from MoBo/over heating CPU
at first go to the bios. then default the bios setting. then check the system monitor. if the cpu is too hot you can see it. or you can change the processor. never over clock the processor.
Jan 20, 2009 | Abit AI7 Motherboard
Hyundai W240D Logo
138 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
