Question about Singer Sewing Machines
When sewing too much thread bunches up underneath fabric
  • Singer Master
  • 7,365 Answers
Try changing the needle
make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted correctly in the bobbin case
also make sure the bobbin is turned the right way in the bobbin
case also
clean under the needle plate and in the bobbin area for lint
Posted on Nov 02, 2012
bargainbox
  • 1388 Answers
SOURCE: Thread bunches on bottom of fabric
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at
www.bargainbox.com.au
Posted on May 10, 2008
RickE1
  • 202 Answers
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
  • 9 Answers
SOURCE: the tension is off ?? bottom thread bunches
Sounds like it could be! Probably worth trying to readjust it. Are you using a fine fabric too? That can cause bunching.
Posted on Apr 06, 2010
Make sure that you have the top thread in all the correct positions. I missed two and had the same problem. When I rethreaded it my problem was solved.
Posted on Sep 06, 2010
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Install a brand new needle.
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Sewing Machine Thread Bunching Up Here Why
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
Feb 06, 2016 | Consew Sewing Machines
Thread is getting bunched up in machine
First thing: install a brand new needle.
Second: remove upper thread. RAISE the presser foot and rethread from the beginning. Set upper tension to the midway point between high & low numbers.
These links may be helpful:
5 Common Causes of Birdnests
Feb 04, 2016 | Sewing Machines
Thread keeps knotting up under the fabric (bobbin area)
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
3 Common Sewing Machine Problems and How to Fix Them
Nov 29, 2015 | Brother XL-5130 Mechanical Sewing Machine
The thread bunches up under the fabric
Your bobbin cotton is probably wound on too tightly
Apr 28, 2010 | Kenmore Sewing Machines
The tension is off ?? bottom thread bunches
Apr 05, 2010 | Kenmore 15516 Mechanical Sewing Machine
Feb 10, 2009 | Kenmore 15516 Mechanical Sewing Machine
Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
Oct 30, 2007 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
48 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
